Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    Mar 2002
    Posts
    17,638
    Exclamation Ove for Volvopaul (or anyone else familiar with IPS oil)
    A friend of mine just found that in one of his IPS the oil looks like in the video below.
    The boat has only been used for a couple of hours after grabbing a line with the props (which is probably the culprit), and since then she didn't move anymore for the last two weeks.
    Not good news obviously, but this chap was expecting to start his well deserved holidays right now, hence the sixty-four thousand dollar question:
    How risky would it be for the transmission to keep using the boat for this month, before hauling her out for prop shaft seals replacement (as I suppose will be necessary)?
    IPS 500 of 2010 vintage, if that matters.
    Thanks in advance!
  2. #2
    Join Date
    Jun 2004
    Anglesey Wales
    Posts
    11,121
    Default Re: Ove for Volvopaul (or anyone else familiar with IPS oil)
    Its hard to tell from that video but the fluid looks really emulsified
    I wouldn't risk it
    Jerk of all Trades Master of None
  3. #3
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,345
    If that’s just “2 hrs and two weeks “ then there’s only one direction / concentration that water in oil is gonna go after a month of use .
    I guess it either sucks it in when running or when stopped - cools down + pressure differential of the bottom of the pod 1,6 M down and the breather air vent in the ER ?
    It’s gonna need doing ( new seal or what ever ) so why hesitate .
    Let’s hope after it’s done your friend can do a long trip to in a man maths or real maths way claw back the expense in alleged fuel savings ??
    Chucking money at it is the easy bit , restoring lost down time with prearranged families impossible.
  4. #4
    Join Date
    Sep 2002
    South
    Posts
    16,746
    The gear teeth are designed to mesh with a thin film of oil of the right spec between them.
    Seriously emulsified oil has really quite different lubrication and cooling characteristics, and running at speed risks trashing the gear set.
    If I was the owner, I would be running on the other engine at displacement speeds until I could get it fixed.
    6kts is not so bad, compared to the cost of an IPS drive.
  5. #5
    Join Date
    Apr 2007
    midlands
    Posts
    7,341
    The advice I will give is if there is the slightest amount of water in an IPS unit don’t even run the engines get it lifted and drained straight away and source the point of water ingress which is usually the shaft seals .
  6. #6
    Join Date
    Mar 2002
    Posts
    17,638
    Blimey P, can it really be that bad? Not that I remotely dare arguing with your competence and experience, mind.
    In the meantime, further checks revealed that also the oil in the other unit is in similar conditions, so the concern is that the line grabbed with the propellers of one pod has nothing to see with the infiltration, which might be due to plain wear and/or aging of some seals instead.
    The engines/pods are 2010 vintage as I said, and they clocked less than 700 hours.
    Btw, the boat has always been kept on the hard and sheltered for about half of each year.
    The local yard is suggesting to pull the pods down for replacement of all seals, and also of the clutch with an upgraded one, while they are at that.
    At eye watering costs, obviously...
    Your view would be highly appreciated, many TIA!
    PS: out of curiosity, by "shaft seals" do you mean the horizontal prop shaft, or the vertical one inside the pod (which I suppose must also have some seals, since the thing has to rotate)?
  7. #7
    Join Date
    Nov 2004
    fareham hampshire
    Posts
    1,723
    If the water has come in via shaft seals would it not be possible to lift boat drain oil and flush replace shaft seals so that owner could complete holidays before major rebuild, Just a thought don't know if viable.
  8. #8
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,208
    Paolo, as others have said, running the Pods in emulsified oil will have only one outcome. Serious cost, and a ruined holiday. Get is sorted immediately. It will only get more costly, and end in a total failure.
  9. #9
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    16,527
    I fear that running the things like this for a few weeks might end up with the owner having to B.O.A.T.T - Break Out Another Thirty Thousand .
    I do like Stelican's suggestion though of replacing the seals and refilling with fresh oil, although the yard may not wish to risk it.
  10. #10
    Join Date
    Jun 2010
    Posts
    964
    It needs coming out, and the suggestion that all the seals are changed is perfectly valid and cheap insurance.
    In reality it is difficult to tell how much damage is done until it is lifted and stripped for a full examination.
    I am old and wise because i was young and stupid.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
