Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,852
    Default Re: Pitting on an iron keel
    Quote Originally Posted by anoccasionalyachtsman View Post
    Just out of interest Vyv, would hot-dipping in Zinc when the keel is still hot from casting be a long (enough) term answer to justify the cost?
    In theory yes, provided the temperature was high enough. Based on my regalvanised chain it might last 10 years. The practicalities might make this a difficult process, assuming most keels are sand-cast.
    Answers to some technical queries at new website http://coxeng.co.uk
  2. #22
    Join Date
    Jul 2006
    Emsworth Hants
    Posts
    12,467
    I would sand blast it I found it was the only way to guarantee all the rust has been removed, rust converters don't work as said, so use Zinc rich epoxy. We had steel boat.
  3. #23
    Join Date
    Feb 2004
    Boat: Portsmouth, Us: Stewkley
    Posts
    3,007
    Quote Originally Posted by vyv_cox View Post
    ISTR galvanisers charge by the weight!!!
    BTW, do cost up the work you are about to do on your keel. The last time I did mine it was a filthy and tedious job and cost me several hundred quid in epoxy primer.
  4. #24
    Join Date
    Mar 2003
    falmouth
    Posts
    16,893
    Had a hot dip galv plant in my factory. You wouldnt need the keel hot from casting - in fact it would need to be stripped back to bare metal which it isnt "as cast". In use the duration would depend on abrasion but you would still have to antifoul and I dont know enough about antifoul paint so say how well that would get on with galv. If its anything like my lead keel, then coppercoat wouldnt work well.
    But the main issue by a long way would be the cost of galvanising a keel. I'm pretty much out of touch with current prices but a quick google suggest around £1 per kg.
    this post is a personal opinion, and you should not base your actions on it.
  5. #25
    Join Date
    Jul 2008
    East coast UK. Mostly. Sometimes the Philippines
    Posts
    9,393
    Quote Originally Posted by birdseye View Post
    I do, though. We once bought a ship that had been built - very slowly, very carefully - in Peru, a country not known for shipbuilding, under the excellent supervision of a firm of Norwegian naval architects who had thoughtfully specified the most expensive of everything. It would be cynical of me to suggest that they might have been on commision. She had 3,700 miles on the clock when she was arrested by the High Court, on her maiden voyage, in darkest Liverpool, and we bought her from the Admiralty Marshal.
    Her builders had thought that it would be a good idea to zinc spray the whole external hull. It wasn’t. Paint doesn’t stick to galvanising under water; it exfoliates. Chain goes from wet to dry, and isn't painted; a hull or a keel stays wet and is painted.
    We had to blast the lot off back to SA 2.5 and epoxy everything. Good ship once we had her sorted.
  6. #26
    Join Date
    Jun 2017
    Posts
    364
    Thought about galvanising, is it £1 per kg keel weight? Sounds like a dealbreaker to me.
  7. #27
    Join Date
    Jun 2015
    Posts
    1,592
    Surely the £ per unit mass thing is just a guide? The amount of zinc used will depend on the surface area of the object. Mental arithmetic says that a 1,000kg keel would have the same area as about 60m of 6mm chain, the mass of which is about 50kg. If I were foolish enough to ignore Minn's experience I'd be negotiating.
  8. #28
    Join Date
    Oct 2003
    BC Canada
    Posts
    675
    I believe from experience and from manufacturers website
    that Primacon contains aluminium and lifts epoxy overcoats
    B.C. Canada.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
