Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Cathead
  1. #1
    Join Date
    Feb 2006
    Bilbo, Spain (Basque Country, actually)
    Posts
    1,851
    Default Cathead
    I recently came across the term "clump cathead" while reading about casting and weighing anchor on old sailing vessels.
    What is the difference between a "clump cathead" and a "normal" common or gardener "cathead" ??? Why is it necessary to distinguish between the two ??
    Or are they the same ???
    Puzzled Plomong
  2. #2
    Join Date
    Apr 2005
    Norfolk
    Posts
    733
    Default Re: Cathead
    A cathead timber extends out, so that the anchor of an old man of war can hang vertically and be dropped without touching the hull.
    The only "clump cathead" I've come across was a sheave mounted on the deck edge of a more modern warships, used when streaming a paravane.
    I wonder if a small merchant sailing ship, having less tumblehome than a warship, would need less extension in the cathead, so may have only needed a sheave in the deck edge to perform the same function.
    East Anglia Yacht Surveys http://www.eastangliayachtsurveys.co.uk
  3. #3
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    5,964
    Default Re: Cathead
    "On each bow is a"clump cathead" from which the anchor is hung when its hawsepipe is required for the bridles of cable for securing the ship to a buoy."
    (Admiralty Manual of Seamanship vol. 1 1951 p.205)
  4. #4
    Join Date
    Jun 2003
    Bangor, N.Ireland
    Posts
    352
    Default Re: Cathead
    I had to look up what a cathead was! This is the definition given in the Oxford Companion to Ships and the Sea. Hope the image works.
    Edit - sorry it comes out on its side! The original was in portrait view.
  5. #5
    Join Date
    Feb 2006
    Posts
    1,851
    Default Re: Cathead
    Quote Originally Posted by dombuckley View Post
    Was the sheave and/or its mounting referred to as a "clump cathead" in this case ????
    That sounds like a reasonable explanation, but some more compelling evidence would be useful.
    I have a poorly-taken photo of an anchor on blocks on deck with the ring end of the shank just on or next to a sheaved block that is integral to the deck edge. That could be a "clump cathead", but I have no idea if that is correct. unfortunately the photo cannot be put up here for all to see.
    Plomong
  6. #6
    Join Date
    Feb 2006
    Posts
    1,851
    Default Re: Cathead
    Quote Originally Posted by Poignard View Post
    I cannot relate that to any part of the 2011 edition to which I have access. Could you give the section and sub-section title so I can make another attempt ???
    Plomong
  7. #7
    Join Date
    Oct 2018
    Posts
    5,964
    Default Re: Cathead
    I'll have a look tomorow
  8. #8
    Join Date
    Feb 2006
    Posts
    1,851
    Default Re: Cathead
  9. #9
    Join Date
    Oct 2018
    Posts
    5,964
    Default Re: Cathead
    Quote Originally Posted by Plomong View Post
    Plomong
    OK here goes.
    It is in the chapter entitled "Anchors and Cables", section entitled "Arrangement of Anchors and Cables", paragraph entitled "(i) In a Large Vessel" .
    There is a drawing entitled " Fig.213 - Arrangement of anchors and cables in a cruiser.". This drawing clearly shows the two clump catheads, one on each bow, facing forward. Each consists of two plates welded or rivetted to the deck and overhanging the edge of the deck with a sheave or roller between them. (They look somewhat like the simple bow roller found on many yachts_.
    On the following page are drawings showing the forecastles of a destroyer and what is described as "a small warship". These do not have clump catheads.
    I hope this helps you but if not, I could perhaps post a copy of the drawing.
  10. #10
    Join Date
    Jul 2008
    East coast UK. Mostly. Sometimes the Philippines
    Posts
    9,505
    Default Re: Cathead
    My 1972 edition doesn’t seem to have it. It has this picture of Arrangement of anchors and cables in a cruiser. This is Figure 11-8 at page 325.
    Annoyingly it then goes on to speak of the hanging off of the anchor at the clump cathead as described in Volume II but my 1981 Volume II seems to have forgotten about clump cat heads.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
