Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
  1. #11
    Join Date
    Nov 2004
    Stirling
    Posts
    14,434
    Default Re: Rigging a boom preventer, and gybing deliberately. Got it wrong.
    One long long line, both ends tied off at the boom and passed through a block at the foot of the foresail does it for us - pull in the slack to the windward side where we control it on a self tailing winch.
    This setup allows a controlled gybe. Best with two people, one for the preventer, one on the wheel/tiller. But can, with forethought and preparation, be managed solo.
    Ω
  2. #12
    Join Date
    Sep 2009
    Solent
    Posts
    1,362
    Quote Originally Posted by LadyInBed View Post
    Even with a preventer why didn't you use your normal method?
    It's a well tested method.
    Good question. The circumstances were rolly. It had been quite hard just to hold course without full concentration. Given I was under the delusion I could dampen the gybe from the midship cleat and would have to go forward and release the preventer anyhow I thought I could kill two birds with one stone.
  3. #13
    Join Date
    Sep 2009
    Solent
    Posts
    1,362
    Dampening using a winch is not something I have used before, or at least it hasn't sprung to mind when it should have. Not enough sailing.....
  4. #14
    Join Date
    Mar 2013
    London
    Posts
    6,388
    Quote Originally Posted by Sgeir View Post
    That is the most appalling diagram but you are excused detention because it is actually a very good way to manage the problem
  5. #15
    Join Date
    Nov 2001
    Me: Johannesburg South Africa Yacht: Richards Bay East Coast Africa
    Posts
    7,028
    I have a very similar setup except I have a large snap shackle at each end of the preventer so I can remove the lazy line so it does not trail across the cockpit.
    before the gybe I release the preventer from the winch/cleat, then during the gybe I centre the boom and change the preventer line and cleat off on the winch.
    Life is too short not to have a sea view
    Distantshaws tinyurl.com/yclt6l68
  6. #16
    Join Date
    Jun 2004
    UK and NW Caribbean, Belize Mexico & Guatemala
    Posts
    377
    Quote Originally Posted by Poignard View Post
    I rig two preventers, one each side. They lead forward inside the shrouds to the bow fairleads then back outside all to a position level level with the cockpit where they are attached to the guardrails with a snap-shackle until required. Attached to the extreme aft end of the boom is a single short strop, having a ring in its free end.
    When I want to rig a preventer I unclip it from the guadrail and clip it to the ring on the strop. Then pay out the main sheet and take up the slack on the preventer, finally tightening it by hauling in the mainsheet as necessary.
    To gybe I pay out the active preventer and haul in the mainsheet hard and unclip the preventer that has been in use. Then transfer the strop to the other preventer, gybe and tension the new preventer as before.
    (takes longer to decribe than it does to do it! )
    + 1 exactly what we do. The preventers are rigged permanently so easy to use and also I use one to hold the boom out to avoid shade on the solars on top of the wheelhouse roof at anchor
  7. #17
    Join Date
    Sep 2009
    Solent
    Posts
    1,362
    Apologies for pushing this. I'm not 100% clear. Does anyone use a proper preventer to dampen / control the gybe. I will certainly be setting up a proper preventer on the boom whatever but using it as a damper in the gybe might suggest a rope diameter kinder to the hands. Diameter suggestions also welcome. Mainsail is 16.7m sq
  8. #18
    Join Date
    Nov 2016
    Lincoln
    Posts
    868
    Not sure why you would when you can use the main sheet to tame the gybe anyway, having the boom quickly swap over like I would in my dinghy days is not something I would like to do now on our yacht,
  9. #19
    Join Date
    Nov 2009
    currently in Pto Montt, Chile
    Posts
    377
    No... I don't use a preventer to dampen the gybe..... if trying to do that I imagine the angle subtended ( I think that's the word ) between boom and preventer would reduce to such a degree as to render it useless.
    I use a preventer ( from end of boom to turning block well frd and back to cockpit.... its designed purpose is as a spin pole downhaul so always ready to go ) to ****prevent**** the boom from moving.
    I always use a very conservative amount of main which makes the next bit easier.....
    When I want to gybe I bring the wind around a bit from right aft to maybe 20º on the quarter... depends on the sea state... then ease to preventer while cranking in the main sheet so boom is almost on the centre line.... disconnect working preventer.... connect new preventer .
    Then helm down ( or up - depending on which side you dress )..... as soon as the wind is across the stern and wind on other side of mainsail ease the main sheet while hauling in the preventer.
  10. #20
    Join Date
    Dec 2018
    Posts
    22
    I've used 2 systems for preventing.
    (1) a line (sometimes a tackle with a snap shackle) led from mid boom (sometimes the eye where the kicker attaches) to turn around a leeward centre cleat or snap onto the shroud base fitting but then back to a cockpit cleat.
    Or (2) a line clipped to a boom-end strop that then runs around a forward cleat or fair lead and (dependent on the boat) back to the cockpit on the windward or leeward side.
    In my opinion, the advantages of (1) are that:
    (a). It will definitely stop the boom moving across the cockpit.
    (b). It is easy to swap over following a gybe - unclip it from the (new) windward fittings, pop it over the coach roof onto the (new) leeward fittings.
    (c). If the boat accidentally gybes, then the preventer cleat is on the (new) windward and uphill side and easy to tend. Can be useful if you're pinned hard over and the (new) leeward side is a bit 'damp'.
    The disadvantage of (1), as another contributor stated is that, in a rolly polly sea, you might bend the boom if you dip it. I will mention that I've never personally dipped a boom, but I know it is a possibility.
    The advantage of (2) is that, in a rolly polly sea, the preventer will stretch a bit and should reduce the chance or prevent boom damage.
    However the disadvantages of (2) are that:
    (a). The angle between the boom and the preventer rope is less orthogonal. From what I have observed the boom usually moves to at least the centreline of the boat before rope tension really builds and the boom is meaningfully 'prevented' - this even if the rope is sweated puckah tight during the set up. Ergo, damage to noggins may still result, though hopefully to a lesser degree. Obviously a lot here depends on the initial boom angle, and therefore point of sail. For those who use system (2) it's worth a 'trial' accidental gybe in a decent blow to check your system's effectiveness.
    (b). It can be a pain to re-rig, involving a trip to the foredeck and end-over-ending the rope, unless there is a clip for the strop on both ends, or you are employing the rather neat system drawn up by a couple of comments above.
    (c). If the return line for the preventer crosses from the leeward bow to the windward and returns to the cockpit along the windward side, following an accidental gybe will be on the (new) leeward side of the cockpit which, dependent on conditions and the degree to which you are 'pinned', may now be a little 'damp'.
    In sum there are pros and cons to each.
    For that reason I tend to use system (1) if I'm in generally sheltered waters with a beginner crew - no risk of dipping the boom, short trips to the coach roof, easy rope work if there's lots of manoeuvring to be had and, most importantly, the boom doesn't budge during an accidental gybe. I tend to use system (2) if I'm on a coastal passage because of the potential to dip the boom, the less frequent requirement to gybe (and therefore re-rig) and the likelihood that the crew will have a bit more sea sense by then. All boats are different, so none of my views should be treated as black and white.
    My key points to the OP are that:
    (a). Whatever system you use, bring it back aft to the cockpit - cleat or winch - so you can ditch in when you need or, more correctly, ease the boom across under control after an accidental gybe (to that end, suggest make sure the rope's long enough to do the latter).
    (b). As previously observed, I'd have it slack and free to run immediately after the "standby to gybe" <or whatever terminology you employ> command. The friction in the main sheet blocks is all I've ever needed for controlling the runout of the main boom after a gybe.
    Great thread and well done OP on thinking about keeping your crew safe.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
