Results 1 to 7 of 7
  1. #1
    Join Date
    Nov 2006
    Limehouse
    Posts
    466
    Default What paint to use when touching up lettering?
    I want to touch up some black lettering on my white fibre-glass boat. What paint is best? Obviously it needs to be able to cope with sea water, sun, cleaning agents...
    Cheers!
  2. #2
    Join Date
    Mar 2017
    Me; Nth County Dublin, Boat;Malahide
    Posts
    804
    Default Re: What paint to use when touching up lettering?
    Is the lettering originally painted on, or is it self-adhesive vinyl? If it is the former a one-pack marine paint would suit, (or Sandtex 10-Year Polyeurethane!). If the latter you will need to obtain some self-adhesive vinyl and patch it in. A few square inches of offcut material can probably be got FOC from your local supplier of shop signage or vehicle wraps.
  3. #3
    Join Date
    May 2001
    Posts
    14,369
    A tube of Artist quality Acrylic paint (costs less than €8) applied with a good brush and a steady hand. The first two will be found in an art-supply shop; the third might not be as easy.
    Note that "Artist Quality" paint, unlike 'Student Grade', contains much more pigment and is usually more light-fast.
    Should we paint what is on a face, what is inside it, or what is behind it?
  4. #4
    Join Date
    Feb 2007
    Essex
    Posts
    22,611
    Quote Originally Posted by PuffTheMagicDragon View Post
    That would work, but if you want a gloss finish any enamel would probably do the job. You probably won't have an undercoat, so a good clean will be necessary to get it to key.
    Far away is near at hand in images of elsewhere
  5. #5
    Join Date
    Jun 2001
    Scotland
    Posts
    6,296
    Quote Originally Posted by ChasB View Post
    Cheers!
    Seeing as you possibly need small quantities then try model paints as used on model planes etc. . You can get Acrylic and enamel in all colours I would go for the latter.
    Eastern Scotland and beyond.
  6. #6
    Join Date
    Nov 2004
    West Mersea. north Essex
    Posts
    4,828
    Quote Originally Posted by Bilgediver View Post
    Yes - Humbrol is your friend.
  7. #7
    Join Date
    Nov 2006
    Limehouse
    Posts
    466
    Sorry for late reply. Busy on boat!
    Will this do do you rerckon? https://www.amazon.co.uk/Winsor-Newt.../dp/B00LHTF4R2
    Will it stand up to oxalic acid based cleaners?
    And what's the solvent/cleaner for this? White spirit? Will acetone do? I'm only anticipating small errors.
    Cheers!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
