Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Jan 2002
    Orwell
    Posts
    4,503
    Default Blakeís replacement
    Iíve discovered my Blakeís inlet and outlet on the head are knackered. I canít really justify hundreds of pounds on bronze replacements. Has anyone found marelon or similar which will simply drop into the same holes? Or do I have to go in for a load of fibreglassing and cutting of new holes? God itís been an expensive summer...:-(
  2. #2
    Join Date
    May 2001
    UK East Coast
    Posts
    36,292
    Default Re: Blakeís replacement
    Quote Originally Posted by Gunfleet View Post
    I’ve discovered my Blake’s inlet and outlet on the head are knackered. I can’t really justify hundreds of pounds on bronze replacements. Has anyone found marelon or similar which will simply drop into the same holes? Or do I have to go in for a load of fibreglassing and cutting of new holes? God it’s been an expensive summer...:-(
    I think the starting point is to price up Blakes replacements, which presumably will just drop in without too much drama. Then price up alternative skin fittings, valves and hose tails, together with details of how much aggravation might be involved in fitting them. You might find that the premium for simple like-for-like replacement becomes attractive.
  3. #3
    Join Date
    Nov 2009
    Southampton
    Posts
    35,519
    If you don’t want like for like, I think standard DZR brass skin fittings and ball valves are more likely to fit the holes than Marelon.
  4. #4
    Join Date
    Nov 2007
    Boat Orwell - Me Norwich
    Posts
    8,086
    The Marelon fittings tend to have a larger external diameter than the bronze for the same nominal internal (pipe) size. (I had to open out the holes in the hull when I replaced (non Blakes) bronze thru-hull fittings with Marelon combined thru-hull/seacock fittings.)
  5. #5
    Join Date
    Nov 2004
    Medway, UK, boat in SYH
    Posts
    2,366
    when you say knackered, what do you mean? pitted or dezincified?
  6. #6
    Join Date
    Jan 2002
    Orwell
    Posts
    4,503
    Quote Originally Posted by RivalRedwing View Post
    I mean the inners seem okay but the coach bolts and bronze outer skin fittings are corroded. Can be pulled apart by hand. Since the outer skin fittings are in the region of £70 each I was thinking letís have done with them and go for reinforced nylon. I know some speak against the marelon or whatever but my first boat had them and I thought they were fine.
    As pvb says though, maybe the amount of work needed on the hull might suggest replacing Blakeís with Blakeís.
    Thanks for comments above everyone.
    Ps if you havenít guessed Iím thinking aloud here. Iím happy to be shown the best logic!
  7. #7
    Join Date
    Nov 2004
    Posts
    2,366
    The outer fittings are about £18 a piece here:
    https://www.sparesmarine.co.uk/websh...ks/all-spares/
    Anglia stainless have regularly been recommended on this forum for the bolts
    https://www.angliastainless.co.uk/marine-fasteners
    discussion about bolts here:
    http://www.ybw.com/forums/showthread.php?210737
  8. #8
    Join Date
    Jan 2002
    Orwell
    Posts
    4,503
    Thanks for these leads. The prices in the chandlery are horrendous!
  9. #9
    Join Date
    Jul 2009
    North Bucks
    Posts
    751
    Quote Originally Posted by pvb View Post
    This advice is spot-on. The blakes valves, properly fitted and serviced should last 30, 40 years? Mine are 30 years old and still excellent. In fact a previous owner replaced a Blakes head outlet with a Bronze/DZR valve ( I don't know why) which subsequently become permanently stuck open, I paid the yard £400 to replace with new Blakes which I already had. It was expensive because the hole in the hull had to be made smaller !
    Andrew
  10. #10
    Join Date
    Jan 2002
    Orwell
    Posts
    4,503
    Iím sure youíre right, though at 67 the idea i might be dealing with boat valves in 30 or 40 years is a bit... odd? Anyway, just up the thread Iíve been pointed to sensibly priced sources for the parts. But you know my local chandlery wanted £70 just for one external skin fitting and the coach bolts!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
