Page 5 of 10 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 100
  1. #41
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,205
    Default Re: So what has gone wrong this year ?
    My boats a 2001 modal .
    So I guess there’s age issues or was .
    In the first season I preventatively had the yard replace the high pressure hoses on the gearboxes , all the black water hoses on the engines , all the sea cocks .
    We also had a top spec discretionary air con system retro fitted by a specialist , along with a new modern smart charger up from 40Ah to 80 Ah .
    A new cockpit fridge , just because wife wanted a new look as the functioning of the existing one was fine it was grubby inside .
    The thinking behind all this seemingly expense came from the fact buying used you obviously save and I bought it a huge discount so in a man maths , more like real maths we had a huge war chest to spend .
    So cost was not the problem as it came out of the buying pot , there was a fair bit left after I homed in it .
    Second reason is that we start with new kit , like a new boat in terms of our expected uneventfully usage.
    That’s been the case .
    Thirdly in a seamanship kind of way and looking over my shoulder at a potential insurance refute battle I just thought new hoses and seacocks were in order with the paperwork to support should it be needed ?
    I’ve probably save £500 to £600,000 buying a used and fettling it over its nearest newer modal in the range .
    I came with 1 year old covers and they are holding up well .
    The seats in the cockpit are coming up for reupholstering in the next couple of years . No rush just mentally thinking with what ??
    I,am on my 5 th season now .
    Mechanically we do all our own service work and it’s never let me down been a show stopper it’s Uber reliable .
    Sure it’s had minor self fix items over the 5 years , a toilet pump impeller , a new tv Ariel , a new GPS mushroom, new water pump on the geny etc .All about €100 or so each .
    But a Jrudge says I enjoy doing that kinda stuff , the Dx , the hunt for a solution , a windy day in port fixing it .
  2. #42
    Join Date
    Apr 2006
    Posts
    1,315
    I refuse to get distracted by Bouba's Sump Pump!
    This year the battery charger decided to go AWOL and not sense when batteries were charged so carried on, and on, and on unbeknown to me. It manifested itself when off shore power and we could not start the engines. Charger was around 8 years old.
    New charger - starter batteries and genny battery
  3. #43
    Join Date
    Oct 2003
    west yorkshire
    Posts
    3,958
    Quote Originally Posted by admillington View Post
    With regard to the Radar, I assume it is Raymarine open array - there is a power switch on the back of the base unit - mine often gets turned off when the boat is cleaned. Worth a try before you take it apart.
    Andrew
    re re the radar; if its a big raymarine open array it is belt driven. I had one get stuck (never used it just tested it once a year)
    opened it up, inside there are two belts that run to and from an intermediate shaft. The intermediate shaft runs in bushes and on mine the steel shaft went rusty and jammed up. Take belts off and spray bushes with penetrating oil, whilst gently trying to rotate the shaft freed it off.
  4. #44
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,205
    Quote Originally Posted by jrudge View Post
    On a light aircraft all hoses a changed every 10 years. My boat is 14 years old ..... so someone who made that decision knows what they are talking about. My winter list .... replace the hoses !
    Yes I feel many on here never really think about the black hoses in the ER .
    Guess there’s a preoccupation with generally keeping running costs down and adopt a sticking plaster attitude - fix it when or if it ever fails . Unbroken stuff just drops to the bottom of a never ending broken list on a boat , I can see that .
    Coming from a Italian exotic classic and new car background it’s very much the other way .
    Although outwardly there’s nothing wrong , the car runs / works etc lads do winter revisions of all sorts of systems .
    Replacing water pipes , air con pipes due to gas leakage , brake pipes , fuel pipes etc etc .
    Obviously a split water hose or union under the car ( mid engine to front rads ) is roadside show stopper and flat bed ride home .
    You need AC there’s tremendous heat soak from moving water and oil about .
    Brake pipes break down from the INSIDE with time and the pressure drops = loose effectiveness.
    Fuel pipes run all over the place in a twin tank mid engined quad carbed engine compartment .If they leak = fire .
    So all that above is life’d effectively on a rolling program of change out .
    Why not on a boat ?? ( where applicable)
    Last winter I changed all the suspension A arm bushes , drop link bushes , shock bushes .Rubber deteriorates now it handles pin sharp .It was fine before I just fancied a firmer sharper control for rallying in the Alps for obvious reasons = steep drops off the edges of passes .
    Chucking money at this kinda car is offsetting unlike a boat by its continued rise in value , so by discretionary spending on something that not broke it helps keep the values up .Sort of looking after the investment.
    You boat is just a huge money pit , you never will get it back so to speak m just the usage of the fixed item .
  5. #45
    Join Date
    Jun 2013
    London. Boat: South of Spain
    Posts
    94
    Outdrive oil seal leak...and BIG rosť leak in the fridge as even the bottles seem to disappear. Other than that just fun...
  6. #46
    Join Date
    Nov 2005
    Sant Carles de la Rŗpita
    Posts
    6,937
    Quote Originally Posted by Whitelighter View Post
    Hardly anything....
    Yea Yea Yea
  7. #47
    Join Date
    Feb 2008
    Farndon
    Posts
    3,012
    All boats seem to have faults waiting to be discovered, or at least faults under development.
    At the weekend I found a bolt and spacer which had fallen off the engine. Both are damaged. Fortunately it looks like the replacements are inexpensive.
    My domestic batteries appear to be in need of replacement.
    Otherwise nothing life threatening although there is always something to do.
  8. #48
    Join Date
    Oct 2003
    west yorkshire
    Posts
    3,958
    whats broken this year?
    so far touch wood etc, nothing.
    we haven't got a tender at the moment so no outboard motor to curse and swear at.
    Well I say nothing, I had forgotten about the duff float switch in the shower pump out box that died last autumn. I discovered the other day that the forward bilge pump has been doing the honours instead. I will be fitting a whale gulper and a manual switch shortly. In the mean time the forward bilge smells vaguely of strawberries.
  9. #49
    Join Date
    Apr 2005
    Looking out of the window
    Posts
    13,934
    Quote Originally Posted by Hurricane View Post
    Yea Yea Yea
    I wondered how long it would take.
    I guessed less than 4 pages....
  10. #50
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    16,321
    Come on Jez, spill the beans!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
