Page 9 of 10 FirstFirst ... 45678910 LastLast
Results 81 to 90 of 100
  1. #81
    Join Date
    May 2001
    Broken Brexit Britain
    Posts
    54,672
    Default Re: So what has gone wrong this year ?
    Quote Originally Posted by petem View Post
    I think Jez was being sarcastic!
    Oh dear sorry to hear that
  2. #82
    Join Date
    Jun 2013
    Posts
    3,439
    Buy a Sealine and a knackered Turbo will be the lest of your problems!
    Yeah, tell me about it. In the last few hundred hours, I have had loads of problems with...................errrrrr, the shower sump.
    Dam I wish I'd bought a 'better' make and had a list of problems to be proud of
    If found in the Brexit forum, please return to the real world.
  3. #83
    Join Date
    Sep 2012
    Henley
    Posts
    818
    Five year old boat.
    1) Weep from heads, replaced seal on pump shaft using £20 service kit.
    2) Sewage pipe from heads to tank blocked with calcified pee. Had to hammer pipe to loosen it and then treat with de-scaler.
    3) Volvo Trim tabs are not working, green flashing leds on both controls which means comms issue. I’ve checked connections and suspect it could be the controller. I’ll probably get Osmotech to investigate and fix.
    4) Had crack in Gell coat repaired, must have been stress crack, I’ve not hit anything.
  4. #84
    Join Date
    Oct 2017
    Posts
    23
    Part way through the season found that the Port engine was not cooling enough, not actually overheating though, but preventing full revs. Investigated first by me, then boatyard, and finally by brought in specialist. During investigations sea-cock flushed to remove any possible barnacle/worm growth, heat exchanger removed and flushed (both fresh and sea water sides), gearbox cooler flushed, thermostats checked. Eventually the problem traced to several impeller lobes partially blocking the oil cooler. As I have never wiped out an impeller in the time I have owned the boat, the bits must have been caught in the seawater system for at least 4 years, but in a location where they weren't enough of a blockage to prevent sufficient flow.
    The main problem, however, for much of the "summer" has been the weather, either too wet or too windy to have an enjoyable time on board.
  5. #85
    Join Date
    Dec 2004
    Posts
    513
    Well I've hardly used the boat this year due to the weather. Almost every time i got the time to go out it was too windy but i did have a couple of nice weekends.
    So this year the following broke or needed work.
    1. Oven hob extractor fan thingy
    2. 2 x water pump bolts...pain getting off
    3. Stbd shaft seals
    4. Hundreds of Oysters up inside the outdrives so they had to come off to clean
    5. New bow thruster prop..trying to cure why i go through so many shear pins
    6. Power steering pump off and serviced and painted
    7. Ended it with my long term partner so now have to sell the boat!
    So all in all not a bad year i'd say...its ended quite well really.
  6. #86
    Join Date
    Jan 2019
    Hampshire
    Posts
    72
    Now that season over for me at least I feel able to comment without jinxing myself I hope. Day 2 generator packs up. Scramble to get someone to look at it and transpires that the starter motor solenoid gone. At same time also notice that the in water alarm valve broken so it wouldn't have shut down if water not coming in to cool!. new starter motor not so easy to come by in August in sardinia anyway managed to get one from somewhere in France but no generator for a while. kids rather sweaty but survived! Toilet blockage - not once but twice! Don't ask but it baffles me that people (girls) chuck things down there after being explicitly told not to! First time got someone to dismantle the loo and pick everything out of the mascerator. second time was able to do most myself but there was also a blockage in the pipe down the line so as to speak so was able to go down there and dig that out too. Williams - am I the only person who hates these machines? Stopped halfway back to boat one day. They are absolute buggers to row without going around in circles! battery dead or at least below proper charge. Charged up overnight, got about 25 starts out of it then same happened again. Tried to get another battery - hopeless. Can't tell if the alternator is simply not charging the battery or whether the battery is knackered so just charged the thing up every other night. Now trying to sort. Few other odds and sods - cleaned out the sump well mid season and the pump duly packed up as i put it back together but somehow managed to get it going again thank God, but no idea how.
    On the plus side the weather was absolutely fabulous. Travelled up the West Coast of Corsica and across to Capraia and down to Elba and have to say without a shadow of doubt the most beautiful part of the Med I have been to thus far. Was Blessed by non prevailing winds which helped but not crowded, incredible topography, amazingly cheap local wines, and great anchorages. After 4 years in the Balearics was glad to have made the move although personally I would avoid most of N Sardinia - too flash and my s58 felt like a tender for most of places we either went or passed by! Thanks for all advice received during the cruise.
  7. #87
    Join Date
    Dec 2005
    Live London
    Posts
    3,761
    Quote Originally Posted by Hooligan View Post
    Rowing a Williams? Lord you deserve a meddle.
    I got a ski rope in it once ( Sardina also) and got a tow from a jet ski. His water plume was landing right on us / in the boat. Given I had no other way of getting back I could not really complain!
  8. #88
    Join Date
    May 2001
    Posts
    54,672
    On the plus side the weather was absolutely fabulous. Travelled up the West Coast of Corsica and across to Capraia and down to Elba and have to say without a shadow of doubt the most beautiful part of the Med I have been to thus far. .
    Sorry to hear about your trials and tribulations but a big +1 for Elba from me. It has some fabulous anchorages and if you can get a berth in Portoferrairo thats a great place to spend a few days. Its also well worthwile renting a car and exploring the island because parts of it are stunning
  9. #89
    Join Date
    Jun 2005
    South of Finland
    Posts
    255
    Nothing else than blocked shower sumps by human hair, in fact, I do not recall anything else failing (knock on wood :-) ) during my ownership since 2015 of the Ferretti 480 anno 2001 than the lock of the sliding cabin door. Lot’s of preventive maintenance has been done though including new seawater hoses, new Manecraft deep sea shaft seals and some other bits. This boat has been one of the rear exceptions (so far...) with virtually no problems. Thanks Ferretti for the good quality of installations and the use of high quality equipment and systems used on board! Keep up the good standard also for the new models pls! Still I do have one strange systematic type of issue and this is that I need to apply the parallel switch to start the engines, also when warm, not a big issue but still a bit strange. All is checked and in order and it seems to be a design error where the battery capacity of 1600 CA at 12 volt from two batteries in parallel is simply not enough.
  10. #90
    Join Date
    May 2001
    Posts
    54,672
    Quote Originally Posted by baylabayla3288 View Post
    Thanks Ferretti for the good quality of installations and the use of high quality equipment and systems used on board! .
    Agreed. The foundation of long term reliability is to fit top quality components in the first place and carry out preventative maintenance. Apart from the sternthruster failure I referred to above, the only other major component I've replaced on my Ferretti is the galley fridge and that was done under warranty by the seller (he says crossing fingers and touching wood!)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
