Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
  1. #1
    Join Date
    Nov 2001
    Medway
    Posts
    19,886
    Default Lets assume that some numbskull has put 50 litres of diesel in their water tank
    The aformentioned twat has drained the tank and " rescued" 30 litres or so of his precious Red.
    Emptied and flushed tank twice, but still that "Eau du diesel" whiff around.
    All that remained then was to kick the water tank filler cap over the side.
    Advice for the idiot most welcome...mainly how to help the pong-go !
  2. #2
    Join Date
    Dec 2007
    S.W. France
    Posts
    7,623
    Default Re: Lets assume that some numbskull has put 50 litres of diesel in their water tank
    The pong will eventually evaporate, but only if you keep changing the air. Apart from slinging the tank, flushing with some detergent a couple of times, then rinsing a few more..
    I assume this 'twat' is a 'friend' on your pontoon? Shurley not anybody you would trust to go out sailing with?
  3. #3
    Join Date
    Apr 2019
    Wales
    Posts
    711
    Have you tried baking soda? It'll take quite a bit I suspect but worth a shot... liquid dettol (original) is a pretty good deodouriser... whether it works on diesel I don't know (it's also easier to get rid of a dettol taste than a diesel taste).
    If you're gonna use detergent (worth a shot), make sure to use warm/hot water and the bio not the non-bio powder.
    However if the diesel has impregnated the plastic, then it might actually be worth replacing the tank. How much is a new water tank?
    (I've had similar issues while in caravan and accidentally hooking up the water tank to the sewage... -___-, I was young).
  4. #4
    Join Date
    May 2001
    UK East Coast
    Posts
    36,292
    If you can do it without taking a chainsaw to the boat, a new tank is your best option.
  5. #5
    Join Date
    Jun 2017
    Posts
    273
    What is your tank and filler pipe made of? What does it serve?
  6. #6
    Join Date
    Jun 2017
    Posts
    273
    Also, where is the whiff coming from...the tap?? The filler tube??
  7. #7
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,339
    If there is room for another water tank elsewhere turn this one into an extra fuel tank and fit a nw water tank rather than scrap this one.
    It is all down to the fact that my wife does not understand me !!
  8. #8
    Join Date
    Oct 2002
    Chichester
    Posts
    811
    Some time ago I wanted to swap a 25l jerry can from diesel use to fresh water. I flushed it several times with hot water and detergent. The pong (and taste) did not go. The pong was permanently in the plastic and instantly communicated itself to the fresh water I put in the jerry can. I think you will need a more 'high tech' cleaning system.
  9. #9
    Join Date
    Feb 2007
    Essex
    Posts
    22,659
    Keel hauling would be too easy. I think that hanging from the yard arm is going to be necessary in order to discourage repetition. I would wash the tank with gin. If the alcohol doesn't mix with and remove the diesel, it will help mask the taste.
    Far away is near at hand in images of elsewhere
  10. #10
    Join Date
    Jul 2015
    Posts
    1,692
    If you have the access to get solids (powder) in and out a fullers earth (probably most easily available commercially as cat litter) will absorb a lot of contamination (it's used in CBRN decontamination). I'd also be looking at the various suggestions there are for getting rid of new paint smell.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
