Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. #11
    Join Date
    Dec 2005
    Far S. Cornwall
    Posts
    13,222
    Default Re: hole in gel coat below waterline after jetwashing, best fix?
    Definitely an old repair, probably not well done in the first place. Good to do while dry, grind back until you find sound edges then fill as above.
  2. #12
    Join Date
    Jan 2012
    plymouth
    Posts
    28,589
    easy job.
    flick off the loose stuff with a screwdriver
    put a sanding disc on your grinder and take the edges back an inch or two to give good adhesion. try not to go too deep.
    fill with some waterproof gunge of your choice. i'd use plastic padding marine. quick and easy to fill and easy to sand to a perfect contour.
    here you go. https://www.boatpaint.co.uk/acatalog...c-Padding.html
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
