Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2014
    Posts
    72
    Default Spitway - Pyefleet to Burnham
    Going to be crossing the Spitway for the first time this weekend. Any advice for a first timer? We plan to leave Pyefleet just after low tide, heading for Burnham.
  2. #2
    Join Date
    Aug 2003
    Colchester, Essex
    Posts
    4,750
    Default Re: Spitway - Pyefleet to Burnham
    Go to Tillergirl's website and use this chartlet. ..
    http://www.crossingthethamesestuary....02019%20V1.pdf
    You need to be east of the buoys for best water, but in my experience with 1.5 m draft I aim to be at the Spitway at LW if going to the Crouch or Medway (from Mersea) so I take the last of the ebb cross at LW and take the flood
    Larry Botheras
    Colvic Victor 35 "Gladys"
  3. #3
    Join Date
    Feb 2007
    Essex
    Posts
    22,874
    There should be plenty of water by the time you get there, but I imagine the Forum creepie-crawlies will tell you to go via the Ray.
    Far away is near at hand in images of elsewhere
  4. #4
    Join Date
    Aug 2008
    me - hornchurch , boat - river crouch.
    Posts
    1,280
    Quote Originally Posted by johnalison View Post
    Not this weekend they won’t , low water is midday ish so unless he has a hovercraft best stick to the wet bit
  5. #5
    Join Date
    Aug 2016
    Posts
    81
    We usually time it to get to the Spitway at or near LW, so you get favourable tide in both rivers. It's more important to get the flood in the Crouch, though, because it's a longer slog if you have to stem the tide, so your timing should be fine. The Spitway channel is very wide and flat, so straying off the line is not a problem - see tillergirl's chartlet to confirm that. Don't worry about it, it's an easy one!
  6. #6
    Join Date
    Aug 2014
    Posts
    72
    Marvellous. Thank you all.
  7. #7
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,436
    Earlier this year i crossed through the Spitway an hour before LW with 1.800 draft and it went down to just 300 mm below the keel. Southern end. I was dead on the line of the buoys.I am confident that my sounder was accurate because i touched off Sales point when not concentrating and just drifting about to waste time to get into Bradwell. Sounder read correctly on the shingle. It was me that was not watching it
    It is all down to the fact that my wife does not understand me !!
  8. #8
    Join Date
    Feb 2007
    Essex
    Posts
    22,874
    Quote Originally Posted by Daydream believer View Post
    I know the feeling.
  9. #9
    Join Date
    Aug 2003
    Colchester, Essex
    Posts
    4,750
    As I mentioned earlier in the thread, the Buoys DO NOT show the best water, see Roger's chartlet on CTTE (Linked in previous post...)
    Larry Botheras
  10. #10
    Join Date
    Aug 2014
    Posts
    72
    Spot on with the advice, we crossed just after LW and had a good run into Burnham. Thanks for all the advice.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
