Results 1 to 9 of 9
  1. #1
    Join Date
    Jul 2009
    South Wales and Bristol Channel, UK
    Posts
    2,508
    Default Switch wiring connections
    I am replacing some of the existing on/off switches with more modern illuminated on/off switches. The replacement switches have 5 colour coded wires; does anyone know how to wire these switches? thanks in advance.
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,614
    Default Re: Switch wiring connections
    The link does not work !
  3. #3
    Join Date
    Jul 2002
    Posts
    43,614
    It has NO and NC contacts so three wires will be for the switch itself......... easily identify those with your multimeter.
    One wire will be the negative connection for the LED and the final one will be the LED positive which you connect according to how you want the LED to operate.
  4. #4
    Join Date
    Jul 2009
    Posts
    2,508
    Quote Originally Posted by VicS View Post
    https://i.ebayimg.com/images/g/YXIAA...e1/s-l1600.jpg
    I am having a problem attaching the link
  5. #5
    Join Date
    Jul 2002
    Posts
    43,614
    Quote Originally Posted by CAPTAIN FANTASTIC View Post
    Try https://www.ebay.co.uk/itm/LED-Illum...3433a74377bb68
    Or just post the ebay item number 162946574362
  6. #6
    Join Date
    Jul 2002
    Posts
    43,614
    No info on the ebay anyway .... gotta sort it out for yourself
  7. #7
    Join Date
    Mar 2015
    Isle of Eigg
    Posts
    7,521
    If you are lucky the contact details will be marked on the darker blue plastic bit. The bit with the wires will(darned well should) unplug.
    see the images here https://www.ebay.co.uk/itm/Waterproof-16-12mm-12V-Car-LED-Power-Push-Button-Momentary-Switch-Metal-ON-
    at least the LED is marked with + and -
  8. #8
    Join Date
    Jul 2009
    Posts
    2,508
    Many thanks
  9. #9
    Join Date
    Jul 2009
    Posts
    2,508
    Quote Originally Posted by Lon nan Gruagach View Post
    Great, very helpful, thank you
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
