Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    May 2005
    up on the moors.
    Posts
    33,340
    Default Navtex aerial orientation
    Trying to mount the new Navtex aerial down below, I can squeeze the aerial into a gap horizontally but not vertically.
    I am sure that there are complicated radiation and reception reasons why this will attenuate the signal, but are the Navtex frequencies 'simple' enough for the signal to still wiggle its way into the receiver component of the aerial, please ? Or do I stick it back on the pushpit rail where I broke the holder a few weeks ago ?
    I think, therefore I am. I am, therefore I sail.
  2. #2
    Join Date
    May 2007
    Posts
    38,100
    Default Re: Navtex aerial orientation
    You may effects where the signal strength depends on the ship's heading.
    I would expect that it will be fine in strong signal areas, as the supposedly vertically polarised signal is much dispersed around the surface of the sea and the structure of your yacht. However, In my simple view, navtex is all about getting weather info far from home, so the best aerial on can reasonably achieve is desirable?
  3. #3
    Join Date
    Apr 2005
    Long Beach. CA.
    Posts
    2,672
    First off put it outside not down below.
    If IIRC most Navtex antennas are 'active' so check the installation instructions as to what and where is acceptable. You won't get zapped but it will likely affect things like the compass.
    W/
  4. #4
    Join Date
    Jul 2009
    Winter in Falmouth, summer on board Rampage.
    Posts
    5,194
    Mine lives in the tiller flat, give good reception and keeps the active antenna dry. The first one died due to water ingress, so I moved it inside.
  5. #5
    Join Date
    Feb 2003
    Posts
    15,663
    Quote Originally Posted by sarabande View Post
    Mine was stuffed in to the headlining horizontally when I bought the boat, I phoned Navtex up, they said it was fine.
  6. #6
    Join Date
    Oct 2007
    Central Scotland
    Posts
    2,360
    Mine is mounted up under the cockpit coaming out of sight in the dry, inside the fibreglass, at about 45degrees to anything and works fine. These very low frequencies are not very polarisation sensitive like VHF is, so you'd hardly go wrong orienting it any way you want. I'd say the orientation should be suit the mounting options more than worry about the signal.
    But you could easily mount it in a place that would attenuate the signal - inside a metal hull! So in an aluminium or steel hull boat, get it up out in the clear. In a plastic boat just get it well above the water line.
    Geoff. C.: Galvanizing and anchor manufacturing.
  7. #7
    Join Date
    Nov 2016
    Lincoln
    Posts
    885
    Ours is fitted inside on the side wall next to the chart table, not had any problems in the last six months since fitting it
  8. #8
    Join Date
    Jul 2018
    Bewdley, Worcs
    Posts
    508
    Quote Originally Posted by PilotWolf View Post
    Why?
    Most boats are plastic, the radio waves really wont care, unlike VHF, it does not need to be "line of sight" so inside is fine, just try to keep it (reasonably) clear of other wiring and electronic equipment.
  9. #9
    Join Date
    Apr 2005
    Long Beach. CA.
    Posts
    2,672
    Quote Originally Posted by rszemeti View Post
    Why?
    Even plastic and wooden boats attenuate radio waves to a point. And you answer your own question - keeping it clear of other wiring and electrical equipment is pretty much impossible inside.
    W.
  10. #10
    Join Date
    Apr 2016
    Posts
    188
    Quote Originally Posted by Daverw View Post
    +1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
