Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Thread: A plastic boat.
  1. #21
    Join Date
    Mar 2009
    Home=Surrey / Boat=Hamble
    Posts
    6,226
    Default Re: A plastic boat.
    With a similar boat.. although I think we have established slightly skinner... my Mitchell has recorded 17.7knots WOT, but that is immediately after launch from fresh anti foul, polished prop and one up, empty water tank & no cruising gear.. (tender/outboards/general shite)
    Engine for others info a Perkins sabre MT225... producing maybe 200-210hp.
    With a seasons weed now on Tulana my trip Friday over to Yarmouth at 2050rpm produced 10knots... if I had opened the throttle I reckon I would have got 13.5knots and got to at 2400rpm..
    So all I would say is how the heck 120hp would ever get the dawg to cruise at 13knots is a mystery to me..
    And Iím a little more attached to the idea of the dawg with kitchen rudder than without.. I still think itís a cool thing.
  2. #22
    Join Date
    Jun 2011
    Volos-Athens
    Posts
    4,847
    Quote Originally Posted by Scarron View Post
    ok, admit I'm confused!
    fig 2 and fig4 show thing open (guess minimal drag) and boat going ahead, right?
    fig 5 implies that there's no astern in prop rotation but you block and return wash back??? similar to my jet tender... must be a dog in reverse!
    fig 6 is pointless (to me!) what's it trying to do? reduce thrust for some odd reason which should be achieved by reducing rpm on the engine? or is it troll mode or something?
    BB, you're absolutely sure that when moving ahead contraption is fully open as fig4 and not slightly closed as in fig6?
    cheers
    V.
  3. #23
    Join Date
    May 2001
    Worcestershire/Pembrokeshire
    Posts
    2,391
    The same thought as vas's last line had occurred to me. would then be like dragging a parachute behind. Is there any way you can unbolt the appendages (temporarily) whilst in the water to try the theory. Scrubbing grid or scuba?
    PS, Still hot & humid out here in TW
  4. #24
    Join Date
    Mar 2009
    Posts
    6,226
  5. #25
    Join Date
    Nov 2002
    Colwell Bay
    Posts
    5,662
    Quote Originally Posted by TheOrs View Post
    One thing that would be relatively easy to rule out and quite important to your calculations is the RPM figure. Can you check it somehow?
    Then maybe do something temporarily with the rudder?
    Yes, a cheapo techo would be easy. That's one easy job to check. By ear, I would say its right. I can also use it to double check that the reduction box is 2:1 which I am fairly certain of.
    Quote Originally Posted by Firefly625 View Post
    And I’m a little more attached to the idea of the dawg with kitchen rudder than without.. I still think it’s a cool thing.
    I would be happy with that set of numbers at end of season.
    What would your fuel burn be at 14 knots? If it was 6 gallons/hr then you pulling 120hp?
    I agree its a cool thing, but if its costing me as many knots as I think it might, its heading to a skip.
    Well, having had the pleasure of being aboard 'The Dawg' last weekend at the Yarmouth speed trials [we weren't entered, we were the finish timing mark! but it took an age to get back from the far end of the course against the spring flood] I can confirm that she is dog slow.
    In my own admittedly biased opinion a 4 cylinder diesel is the work of the devil so a 6BT it has to be, with tons of engine box sound proofing and a big bore well silenced exhaust.
    I agree that it must be several tons of drag from the enormous kitchen rudder, have you a picture of the actual appendage you can post? for those not familiar with the principle [as I wasn't] this is the thing and it's like towing a blinking parachute.
    Attachment 80798
    Best thing for that thing is to take a gas axe to it and drop in a nice new blade job with a pair of thrusters.
    Then your 220 hp Cummins should get you into the mid teens and the ability to punch the tide through Hurst narrows without a care in the world.
    Yes, I agree with that. Except, I think the higher revs of the 4BT mean I can keep the current gearbox. Shame the box with that 4BT is not the right ratio, although I'm not sure if its cost effectively changeable. That needs a bit of thought.
    Thank you. Yes, mine exactually the same.
    Quote Originally Posted by vas View Post
    50/50!!
  6. #26
    Join Date
    Jan 2003
    in limbo at the mo.
    Posts
    7,768
    Not wishing to butt in on the thread, i simply find it interesting, it may be worth having a google at the Lochin 33 speed an keels on the web, similar type threads to this, goes into detail about props, engines and keels etc, the cutaway keel on the Lochin, as opposed to full keel band (for taking the ground) gives a difference of 2-5 knots using the same engine, The Kitchener rudder must slow the boat, i would have thought, if you are bored it may be worth having a google, it may give you some ideas, i am well aware the OP knows exactly what he is doing, i just thought i would mention it, getting my coat now
  7. #27
    Join Date
    Nov 2002
    Colwell Bay
    Posts
    5,662
    Quote Originally Posted by Davy_S View Post
    Welcome input thank you, I will waste time at work googling Lochin keels.
    I see you are in limbo, in which case I can help you out with a beautiful Huntsman 31! I broke the first rule of Fairey boats and bought my next boat before selling the previous one. Erk!
  8. #28
    Join Date
    Mar 2009
    Posts
    6,226
    Donít know what my fuel burn would be at 14knots.. Iíve never cruised at that.. at a guess 4.5 gph
    I think if you junked your kitchen rudder it may just feel like youíve let the handbrake off... but would be sad to see it go!
  9. #29
    Join Date
    Jan 2009
    Lochaber
    Posts
    7,252
    As was said, simple to calibrate the tacho against a cheap non contact one. My Levi Corsair has two na Ford's on shafts, at 1200rpm does about 6.5-7kn at roughly 6l/h. Flat out won't quite make 17kn. 2300rpm gives 15-16kn and roughly 40l/h. One engine wasn't right when I got her, overhauling the fuel pump made a big difference. I have messed about with the stops to make sure both will reach max revs in neutral and the fuelling to get max revs loaded without smoking.
  10. #30
    Join Date
    Jul 2014
    london
    Posts
    101
    An ignition timing strobe (that of course would be totally redundant on a diesel) should be able to confirm the max rpm at WOT. I don't know if there is an equivilent when it comes to marine diesels, but with avgas burning aircraft engines, the guide of 5usg per hour per 100hp is a pretty reliable indication of output? My guess is that under way, your rudder arrangement is essentially acting as a large sea anchor. I reckon glassing in a bow thruster and going back to a rudder blade will be your way forward... Looks like fun though.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
