Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
  1. #1
    Join Date
    Dec 2010
    Posts
    8,649
    Default Lazyjacks re-think
    This may not work, or even be worth trying...just a thought. The long down-parts on my lazyjacks are a pain, leading to the shroud bases. These tails almost double the length of line required, they tangle easily and aren't close to hand when I need to adjust them.
    I'm thinking that if the line on each side began at the spreaders and led down through the usual triangles to the boom, the aftermost part of which was adjustable with a boom-mounted clam-cleat, then the tension could still be altered but the amount of rope needed could be much reduced.
    Also, is there an overpowering reason why lazyjacks are attached close to the mast, rather than out on the spreaders? If the lines could be spread (permanently, or temporarily with an adjuster), there'd be much less snagging of battens.
  2. #2
    Join Date
    Sep 2010
    Where life is good
    Posts
    14,010
    Default Re: Lazyjacks re-think
    Mine start on the boom.
    Go up to a block on the spreaders
    Then back down to a cleat at the goosneck.
    They are over length so they can be released and the middle lead all the way back to goosneck so there is nothing to catch the battens when hauling the main.
    Life is too short to drink bad wine.
  3. #3
    Join Date
    Jul 2002
    Farnham, Surrey
    Posts
    21,404
    Ours come down to cleats on the mast near the gooseneck. We’ve never had any problems except taking care to look aloft when hoisting the main. I don’t usually touch them or adjust them in any way.
    Semper aliud
  4. #4
    Join Date
    Jun 2004
    Fareham
    Posts
    6,658
    On my boat they are rigged as you suggest. There is a fixed length of rope attached to the middle of the upper spreader with the top block of the cascade on the other end. The bottom rope of the cascade passes through all the various blocks and ends on a cleat on the boom near the gooseneck. There is enough spare rope there to all the whole system to be pulled in against the mast if required. In practice I very rarely adjust them. I raise the boom a little to give enough slack to ease fitting of the sail cover.
  5. #5
    Join Date
    Dec 2003
    Posts
    5,545
    System is fine in principle, subject to spreader specs and lazyjack loads. I’ve seen a broken mast following a bust spreader as a consequence of such a system, but on the other hand it works fine on many boats. Other option is to rig from mast and open slot with lightweight bungy.
    Prob best to ask the spreader manufacturer or rigger before installation
  6. #6
    Join Date
    Nov 2009
    Southampton
    Posts
    35,600
    Quote Originally Posted by dom View Post
    I reckon that's probably overkill on an elderly dinghy
  7. #7
    Join Date
    Dec 2003
    Posts
    5,545
    Quote Originally Posted by prv View Post
    Good point, non-trivial exercise fitting lazy jacks to my Laser
  8. #8
    Join Date
    Jun 2004
    Fareham
    Posts
    6,658
    Good point. As I understand it the spreaders should be strong enough to support the weight of a rigger standing on them. But probably a good idea to ensure that the lazy jack ropes are not too strong. No comments on ours in the rig inspection just after we bought the boat. You've now got me thinking about adding a hanger from the mast to support the middle of the spreaders where the lazy jacks are attached.
  9. #9
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,274
    The solution has got to be full length battens
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  10. #10
    Join Date
    Sep 2004
    Posts
    318
    Quote Originally Posted by dancrane View Post
    They need to be close to the mast to pivot with the sail/boom when sailing (unless you remove them). If they, for example, went to the end of the spreaders it would pull tight as you have the boom on the opposite side.
    Live long and die happy - and may the skin of your arse never cover a banjo. TJ.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
