Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
  1. #1
    Join Date
    Dec 2010
    Posts
    8,649
    Default Sikaflex at Screwfix
    I want some clear sealant of a good grade for odd deck-leaks. Whenever I've used Sika in the past I made a horrid mess, so I reckon I can minimise that by buying clear.
    It's at Screwfix for under £7 (300g). https://www.screwfix.com/p/sika-sika...ar-300ml/7286d
    Is that unfamiliar cheapness representative of it being substandard, compared with the white 291 and 292 I've bought previously, or does it just show the price Sika ought to be, rather than what I've always paid at Force 4?
  2. #2
    Join Date
    Jul 2004
    Sussex-Hampshire coast
    Posts
    918
    Default Re: Sikaflex at Screwfix
    I've been using Puraflex 40 from toolstation for 5 years instead of Sikaflex and its worked well, £5.28 a pop!
    https://www.toolstation.com/puraflex...e-300ml/p85566
  3. #3
    Join Date
    Dec 2010
    Posts
    8,649
    Thanks for that. Actually it's not really a cost issue, though I'm interested. I'm told that CT1 is the best bet, because even if the surfaces it is used on are not dry, it bonds and seals. I'm wary of using CT1 because I always make such a hideous mess with sealant, and because CT1 is said to be immovable once cured. I suppose it could be shifted mechanically but I don't want to make things worse.
  4. #4
    Join Date
    Mar 2008
    Argyll
    Posts
    6,365
    Sika make a considerable range of sealants and adhesives for a myriad of different purposes, even some of that nasty silicone,I would not use any of them without having plenty of paper and masking tape handy. Clear stuff will go murky very quickly so it is no better.
  5. #5
    Join Date
    Mar 2017
    Me; Nth County Dublin, Boat;Malahide
    Posts
    841
    Masking tape helps to reduce the mess. It might seem like a faff, taking longer to do the masking than the sealing, but better in the long run.
  6. #6
    Join Date
    Dec 2010
    Posts
    8,649
    Thanks, I had some old Sellotape in mind, but I'll get proper masking tape.
  7. #7
    Join Date
    Jun 2005
    Mid Devon
    Posts
    6,442
    Get some "Wonder Wipes" and you'll never have a mess problem with Sika again!
    Brexit: Taking back our freedom as a sovereign nation.
  8. #8
    Join Date
    Sep 2012
    Northern Ireland
    Posts
    564
    A few years ago I got 10 tubes of Sikaflex for about twenty quid because they were a month out of date. It was as good as in date stuff. I haven't had as good a deal since then but keep your eye open for deals like that.
    Kind Regards
    Skip
  9. #9
    Join Date
    Dec 2010
    Posts
    8,649
    I hadn't heard of Wonder Wipes.
    I found many packs of out-of-date "Sugru" mouldable rubber at a B&Q 18 months ago. They sold me the lot at £1 each, about a 75% reduction. It's still fine now.
    I was eventually persuaded by glowing reports about CT1, which Screwfix doesn't stock...
    ...I went to Travis Perkins and the lad there said the "Hippo" brand is better, and cheaper than CT1. I've never been let down by their products or recommendations, so that's what I bought.
    Interestingly, when I asked if the Hippo brand sealant was available clear rather than coloured, I was shown the sample tray - a variety of colours and the clear really is very clear.
  10. #10
    Join Date
    Dec 2014
    N of Ardnamurchan, winter Loch Melfort
    Posts
    925
    CT1 is very much an adhesive. I've used to fix wooden trim to the galley worksurfaces, and it is certainly permanent.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
