Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Jun 2001
    home Brum, boat Costa Brava
    Posts
    3,958
    Default KAD43 salt water in engine bilge
    Hi
    Iím getting about a litre per engine hour salt water in one of my my engine bilges. Iíve had seal leaks from water pumps in the past and itís not that and there is no obvious drips from pipes or the filter. Where else could it have come from?
    Cheers
    David
    Sealine S37 by the way
  2. #2
    Join Date
    Feb 2008
    Farndon
    Posts
    3,059
    Default Re: KAD43 salt water in engine bilge
    Quote Originally Posted by DavidJ View Post
    Hi
    Cheers
    David
    I understand the steering on outdrive boats can let water in if not greased.
  3. #3
    Join Date
    Oct 2014
    Posts
    102
    What stern gland arrangement do you have ?
  4. #4
    Join Date
    Feb 2008
    Farndon
    Posts
    3,059
    Quote Originally Posted by STILL AFLOAT View Post
    It's on outdrives.
  5. #5
    Join Date
    Oct 2014
    Posts
    102
    Quote Originally Posted by MartynG View Post
    It's on outdrives.
    OK, Ive never had outdrives, but they have to be sealed somehow ?
    Mebbe try a large mirror & torch ?
    Otherwise, perhaps a cracked hose somewhere in the system.
    At least you have isolated the problem to just 1 engine.
    Yes We know, it can be darn awkward, gettin into all the nooks & crannies, but, you will just have to persevere, with all means at your disposal.
    Do you do your searches wit the engine off, or running ?
    That could make a difference ?
    Best of luck !!
  6. #6
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,352
    1L / hr when ?
    Engine running or / and off ?
  7. #7
    Join Date
    Jun 2001
    Posts
    3,958
    Quote Originally Posted by Portofino View Post
    1L / hr when ?
    It seems to be with usage which fits with Martyn’s theory especially that I haven’t greased the outdrive steering for some years.......kind of slipped from my regular maintenance routine.
    I’ll grease it up tomorrow and see how it goes.
    Thanks all for very fast responses
    Cheers
    David
  8. #8
    Join Date
    Mar 2002
    London
    Posts
    8,107
    Exhaust elbow and seals?
  9. #9
    Join Date
    Jun 2001
    Posts
    3,958
    Quote Originally Posted by gjgm View Post
    Hmmm hope not but Iíll check
  10. #10
    Join Date
    Apr 2007
    Mallorca
    Posts
    610
    The most common places for sea water leaks on these engines excluding the sea water pumps are exhaust elbow cracked, exhaust down pipe corroded, aftercooler matrix leaking, oil cooler leaking (early ones only).
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
