Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Join Date
    Jun 2001
    home Brum, boat Costa Brava
    Posts
    3,943
    Default Re: KAD43 salt water in engine bilge
    My goodness the possibilities get worse!!
    Iím greasing up tomorrow and will run the engines for a while and see if any water comes from anywhere. Itís going to be a blowy day so wonít be taking the boat out.
  2. #12
    Join Date
    Jun 2004
    Guernsey
    Posts
    3,071
    Also check below the oil cooler, they start to corrode and leak, if there is evidence of a leak remove and dismantle cooler.
  3. #13
    Join Date
    Jun 2001
    Posts
    3,943
    Ah!
    It was the water pump after all which I guess is a good thing. Iíve replaced the seals and shaft before so Iím thinking it might be a new pump job.
    Thanks to all and at least it made me grease up the forgotten outdrive.
  4. #14
    Join Date
    Mar 2004
    Posts
    6,037
    there is a bearing at the top of the helmet, needs greasing.
    total pain to get to, but worth sorting.
    you may be able to force new grease in / through when it is hot from having used the engine.
    else you'll need to take the nipple off and poke the hole to the bearing.
    then you can set up an extension and grease it from a more reasonable location, pm me.
  5. #15
    Join Date
    Jun 2001
    Posts
    3,943
    Quote Originally Posted by simonfraser View Post
    I didn’t know about that one!
    The problem is identified now, the pump, so not looking for further work. However I will look at the helmet bearing when the boat comes out for bottom scrub and new gaiters next spring.
    Thanks for your advice.
    Cheers
    David
  6. #16
    Join Date
    Oct 2014
    Posts
    96
    Quote Originally Posted by DavidJ View Post
    OK, this may or may not be useful...
    I bought an used Broom 37, where some previous owner, just used universal grease, on the steering.
    I didnt know the difference, between Grease Guns, and stupidly, without google, just bought a cheap chinese one !
    Due to the solidified universal grease, the grease gun was useless !
    On advice, I went to the local WŁrth shop, and paid a lot ( Well about 90 Quid )
    for a hand held high pressure grease gun, with a locking snout & a couple of water resistant WŁrth grease cartridges !
    Even with the high pressure grease gun, nothing was moving !
    A mate, came on board, looked at the problem, & said, well, before hauling out & having to take the system apart, lets use the honey idea !
    Honey Idea ???
    Yes, old honey, goes white n can crystalize, same as grease can !
    So, for about 20 mins, my knowlegable mate, played a heat gun, up and down the stainless shaft, and the grease area.
    Once the grease, started to bubble, around the top of the stainless shaft..
    My mar°te yelled
    Pump !
    Sure enough, pumping away, the window putty like, white grease was slowly expelled, and finally the dark greenish WŁrth grease, came through !
    Not had a problem, since !
    Good Luck !
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
