Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 59
  1. #31
    Join Date
    Nov 2009
    Antofagasta, bound North...
    Posts
    384
    Default Re: Arctic- what 40-45' yacht?
    Quote Originally Posted by Minn View Post
    I have no idea why people talk about exploration yachts; all the exploring has been done. Likewise expedition yachts. People are just cruising like anywhere else.
    You can charge the punters extra if you have an 'expedition' yacht?
  2. #32
    Join Date
    May 2007
    Cambridge, UK
    Posts
    6,171
    The main thing to bear in mind is that you will encounter ice - perhaps not in Iceland, but certainly in the inner parts of the fjords of Svalbard. As others have mentioned, GRP isn't ideal for that; steel, alloy or wood are preferable (the first two can take the knocks; you can protect the latter with a couple of sacrifical planks round the bow). The problem isn't big stuff - it's the sort of ice rubble that is difficult to see and therefore pretty much unavoidable.
    In summer it won't be all that cold - usually above freezing in the western part of Svalbard and Iceland; Svalbard has a strong west-east temperature gradient, and is much colder as you go east. A sheltered helm position is valuable, and of course, good heating.
    Bear in mind that there is (for practical purposes) no SAR in Svalbard, and unless things have changed, you are required to demonstrate that you are self-supporting (it used to be the case that when you arived at the airport, the first question you were asked was "Where are your supplies?" and if you didn't have a good answer, you were going back on the same aircraft!). I think this has eased up a bit these days, but bear in mind that Longyearbyen is still very much a company town.
    In Svalbard you are required to carry a rifle for protection against polar bears. I think these can be hired at Longyearbyen - they certainly used to be.
    In Svalbard, don't expect charts to have the complete coverage we are used to - keep a good lookout and navigate cautiously.
  3. #33
    Join Date
    May 2018
    Posts
    42
    Steel/Aluminium, Expedition yachts? We don't see any of these. Just take your med-style grp gin palace and go.
    Attached Images Attached Images
  4. #34
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,504
    Quote Originally Posted by stingo View Post
    What a great photo, Minn.
    EDIT: You've added a photo! For clarity, I was referring to the first photo.
    I think they are both good photos. I really like the yacht, especially the cockpit (and decent dorads) in the second photo.
    Jonathan
  5. #35
    Join Date
    Mar 2008
    Argyll
    Posts
    6,369
    I brought a couple with an Oyster 47 cutter through the canal today, on their way back from Northern Norway and the Arctic Circle, they told me of some of their other destinations including The North West Passage (failed to get right through) and the Falkland Islands. Multiple winners of the RCC Tilman Medal they seemed to regard it as just normal cruising.
  6. #36
    Join Date
    Jul 2007
    Sailing the Aegean
    Posts
    839
    I think I would like the security of a steel hull with an encapsulated keel and skeg protected rudder if I was going into these waters with unknown chunks of ice floating around, either on the surface or semi submerged.
    I'm not to sure on an alloy hull, I've never been too keen on the idea, I may have read to many horror stories about them.
    This has just popped up on eBay that would certainly suit the bill, not sure what price brackets are relevant.
    https://www.ebay.co.uk/itm/12-6m-Cut....c100903.m5276
    But if steel or alloy I would certainly recommend a full ultrasound and corrosion survey to be sure of not buying a colander!
  7. #37
    Join Date
    Feb 2007
    West London
    Posts
    2,972
    Quote Originally Posted by grumpygit View Post
    I think I would like the security of a steel hull with a skeg protected rudder if I was going into these waters with unknown chunks of ice floating around, either on the surface or semi submerged.
    This has just popped up on eBay that would certainly suit the bill, not sure what price brackets are relevant. https://www.ebay.co.uk/itm/12-6m-Cut...-Sailing-Yacht
    Nothing on that link.
  8. #38
    Join Date
    Jul 2007
    Sailing the Aegean
    Posts
    839
    Quote Originally Posted by scotty123 View Post
    Try this one. https://www.ebay.co.uk/itm/12-6m-Cut....c100903.m5276
  9. #39
    Join Date
    May 2007
    Cambridge, UK
    Posts
    6,171
    While I appreciate the advantages of an encapsulated keel for other reasons, it probably isn't relevant to the dangers of ice. A lump of ice deep enough to interfere with the keel of a sailing boat is big enough to be readily visible and avoidable, and it is extremely dangerous to get close to ice of that sort of size; small bergs can overturn without warning, posing serious risks to any form of construction. The reasons for preferring metal construction are resistance to constant impact with small lumps of ice - pieces less than a metre across, mainly. Anything as deep as a metre or so should be avoided like the plague, as you're probably looking at something at least as heavy as a yacht with the potential for sudden overturning. Having seen icebergs overturning, I can assure you that you don't want to be anywhere near them! This photo shows the range of things encountered
    PS: - remember that there's a LOT more ice below the surface than above!
    PPS. - The white streak on the water below the mountains on the right hand side of the image is a raft of the sort of rubble ice that is difficult to avoid. The rest are all of sizes that are best avoided.
  10. #40
    Join Date
    Dec 2003
    Posts
    5,550
    Quote Originally Posted by AntarcticPilot View Post
    Crikey
    These kind of expert insights help explain the rationale behind the 'panzer' polar vessels: heavy, expensive, highly self sufficient, mostly narrow in purpose, and slow under sail owing to quite modest amounts of hull-based ballast.
    But what a stunning world we know so little about up there !! Tks to the artic/antarctic contingent on here for the insights and fantastic pics. Never knew there were so many of you on here
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
