Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Aug 2012
    London
    Posts
    20
    Default Re: Paper towelling in fuel tank!
    Only work on the tank was diesel bug last year where the tank was completely cleaned (and fuel polished) and boat has had a few hours put on since. Fuel itself was as clean as a whistle with no evidence of diesel bug so can't believe that paper was in there then and given the time, the individual sheets were still relatively intact.
  2. #12
    Join Date
    Jun 2001
    uk
    Posts
    2,332
    Had a dead mouse, reckon it has rested on a shelf in the tank since build, ten years later !
    David
  3. #13
    Join Date
    Feb 2008
    Farndon
    Posts
    3,037
    Fuel filters are made from paper . So fuel perhaps doesn't dissolve paper towels?
  4. #14
    Join Date
    Aug 2012
    London
    Posts
    20
    You learn something every day!
  5. #15
    Join Date
    Mar 2013
    boat conwy
    Posts
    3,765
    Quote Originally Posted by Martin1976 View Post
    how did you see full sheets in your tank
  6. #16
    Join Date
    Aug 2019
    Posts
    13
    what a nightmare. I know a bloke who had all sorts of problems with an engine cutting out and invested a lot of time and money into getting it sorted and it turned out that he had his tanks 'professionally' cleaned after having the bug and they had left a mop head in there.
    As everything sloshed around, the mop head would get sucked to the pickup, engine would stop, mop head would drop off and engine could restart and the cycle continued
  7. #17
    Join Date
    Apr 2007
    midlands
    Posts
    7,329
    The most important and most problematic find in a fuel tank I found when looking for a fuel starvation problem was a metre length piece of sikkaflex, this was partially sucked up the stack tube .
    This was on a sealine Sc 29, this happened again on 2 different boats .
  8. #18
    Join Date
    Feb 2008
    Suffolk
    Posts
    3,699
    Not boat related, but a long time ago my wife had a problem with her MGB (I said it was long time ago!) which kept stopping and then restarting a few minutes later, went to the local garage a couple of times and they were baffled so decided to remove the fuel tank, she rang them up and they said we've found the problem but you have to see for yourself - they had found a golf ball in the tank which had unravelled itself - the strings of rubber kept going up the pipe and blocking it. No idea how the ball got there.
  9. #19
    Join Date
    Nov 2004
    fareham hampshire
    Posts
    1,723
    Had problem intermittent fuel starvation710hp cat caused by pipe blanking tap in tank picking up happened 4 times. Put Endoscope in tank and luckily found it
  10. #20
    Join Date
    Nov 2002
    Colwell Bay
    Posts
    5,659
    I had endless blockages on one tank. constant source of fibrous crud in the filter. Eventually I emptied the tank and cut an inspection hatch in the top. I found the remains of a wooden handle wire brush disintegrating.
    I reckon it had been there since Fairey built the boat in 1969.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
