Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Jun 2001
    Corfu - mostly
    Posts
    5,366
    Default Engine overheated - should I change the oil?
    My engine (Beta 35) overheated yesterday. The alarm went just outside the marina and we had to sail back in.
    Don't know what caused it. Its a heat exchange system. Plenty of coolant. Impellor good. Filter clear. Perhaps the raw water inlet was temporarily blocked. I poked down through it, and it seems fine now, with a good through-flow to the exhaust.
    The engine seems to be OK, but have I read somewhere it is advisable to change the oil after overheating? Are there any other checks advisable before I head out again?
  2. #2
    Join Date
    Feb 2008
    Farndon
    Posts
    3,047
    Default Re: Engine overheated - should I change the oil?
    If alarm sounded just for a few seconds there should be no issue . Oil level is presumably as it should be.
  3. #3
    Join Date
    May 2007
    Posts
    38,184
    Is this an exhaust overheat or the closed circuit engine coolant overheating?
    If it didn't lose much coolant it's very unlikely the oil got too hot. And if it did, that's probably least of your worries.
  4. #4
    Join Date
    Nov 2001
    scotland
    Posts
    3,432
    If it was water shortage then the exhaust system should be inspected especially any plastic components
  5. #5
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    20,314
    The oil temp gauge on my new car reads 130 degrees C if I'm caning it so unless you went a lot hotter than that, I wouldn't worry.
    Richard
  6. #6
    Join Date
    Nov 2007
    Boat Orwell - Me Norwich
    Posts
    8,225
    Quote Originally Posted by RichardS View Post
    Richard
    You haven't accidentally ended up with a model fitted for the post-Brexit market with the temp gauge in Fahrenheit have you?
  7. #7
    Join Date
    Oct 2014
    Australia
    Posts
    248
    The short term overheating shouldn't cause any harm to the the oil. It would take overheating serious enough to cause deformation of metal parts etc to adversely affect the quality of a modern engine oil. The engine would probably be destroyed by this event.
    What happened to you has been probably beneficial to the oil evaporating some of the ever present harmful water content ;-). Don't worry.
  8. #8
    Join Date
    Nov 2009
    Posts
    20,314
    Quote Originally Posted by LittleSister View Post
    It's a German car so Fahrenheit is definitely a non-starter .... even though one of their Guys invented it.
    Here's a confusing fact: -40 degrees C is the same temperature as -40 degrees F.
    Richard
  9. #9
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,614
    Richard
    Not confusing at all ... It forms the basis of an easy to remember method of converting one to the other:
    Add 40
    Multiply by 9/5 to convert C to F or 5/9 to convert F to C
    Subtract 40
  10. #10
    Join Date
    Jun 2017
    Posts
    776
    Quote Originally Posted by VicS View Post
    Add 40
    Subtract 40
    What???
    It's: C x 9/5 + 32 = F, or F - 32 x 5/9 = C
    32 is the difference between freezing points, 0C = 32F
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
