Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Join Date
    May 2018
    Posts
    180
    Default thicker standing rigging?
    my westerly 31 has 6mm (11 strand) diameter ringing except the wire that goes through furler which is 8mm. Thinking of replacing all rigging with 8mm. Is there anything wrong with that? mechanically speaking?
    Do it yourself and do it good!
  2. #2
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,618
    Default Re: thicker standing rigging?
    Quote Originally Posted by Akestor View Post
    Using thicker wire is no problem as such but I would only tension it to the same figure as the original. If you tension it to the figure you would normally set it to for the thicker wire you could be setting it to a tension the boat is not designed for.
    But why increase from 6 to 8 ? Need a stronger rig or just money to spend?
    11 strand ? Is that right ?
  3. #3
    Join Date
    May 2007
    Posts
    38,328
    Thicker standing rigging can mean the leeward shroud goes completely slack too soon.
    Probably not going to hurt a Westerly 31, but it's really just pointless weight aloft.
  4. #4
    Join Date
    Oct 2001
    Posts
    1,428
    Quote Originally Posted by lw395 View Post
    All other things being equal, thicker rigging would be less stretchy than thinner, wouldn't it?
    Certainly works that way for cordage.
  5. #5
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    6,575
    Thinking I knew better than the designer of my boat (Kim Holman), I replaced the 5mm shrouds specified on his drawings with 6mm.
    I then found that the terminal eyes in the new shrouds were larger in diameter than the originals, and this meant that the clevis pins in the mast tangs were no longer a snug fit in the new eyes, as they had been in the old. I didn't like this.
    I had to turn up some thin-walled s/s bushes to take up the slack.
    Not a problem as I have a lathe, otherwise I would have had to pay someone to do it for me
    "Brexit: like watching a library being burned down by people who can't read"
  6. #6
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    21,978
    Quote Originally Posted by James_Calvert View Post
    Ultimately that is true but you only tension your rigging to around 20% of UTS. Sailing loads will add a bit but nowhere near enough to stretch the wire significantly.
    Answers to some technical queries at new website http://coxeng.co.uk
  7. #7
    Join Date
    Mar 2005
    East Sussex.
    Posts
    21,424
    If it was designed for 6mm wire. and has worked OK with it for many years, why change? If you fit thicker wire you cannot tension it to the same percentage without risking damage to chainplates and possibly distorting the boat so that things happen like cabin doors getting stuck.
    Working on immortality - One day at a time.
  8. #8
    Join Date
    May 2018
    Posts
    180
    Quote Originally Posted by VicS View Post
    hi Vic you are right i got it wrong! actually it should be 1x19 strand wire continuous according to boat specs unless last rig replacement was set differently. I experienced some heavy weather with the meltemi in aegean sea. Had some strong "flaps" of the jenoa going downwind ( shaking rigging) and splashing into big waves going upwind. These sudden stresses at the rigging makes me think of the 8mm, but then i hadn't though of the tension factor.
    I relize that know. It's like setting thick bass strings to a mandolin
  9. #9
    Join Date
    May 2018
    Posts
    180
    Quote Originally Posted by Norman_E View Post
    I ll stick to the 6mm. Stupid but didn't think of the foundamental factor of tension difference!
  10. #10
    Join Date
    Mar 2005
    East Sussex.
    Posts
    21,424
    Good call to stay with the original design IMHO. I suggest that you get yourself a rig tension gauge. I use the largest size of Loos Professional gauge as my rigging is mostly 10mm, but the smaller one that reads wire sizes to 7mm will do for you because your 8mm forestay has its tension set by the backstay and is not measured directly. It is important that you keep your rig properly tensioned because a slack rig is more likely to fail than one kept properly tight.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
