Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Volvo 41P
  1. #11
    Join Date
    Jul 2019
    Posts
    25
    Default Re: Volvo 41P
    Quote Originally Posted by Alanij View Post
    I freely admit to not having a clue what the access is like on the smaller 7.60 the OP was asking about.
    I’ll find out tomorrow. From the photos I’ve seen there would appear to be a small hatch in front of the main access hatch which would give access to the water pump.
  2. #12
    Join Date
    Jun 2001
    UK East Coast
    Posts
    1,855
    Quote Originally Posted by Jamie Dundee View Post
    Don't let the not so good seawater pump access influence your purchase. If you want better access I can share pictures of the modification I have made to make it easier. Good luck with the viewing.
    www.solocoastalsailing.co.uk
  3. #13
    Join Date
    Jan 2012
    South Coast
    Posts
    5,202
    I would remove the zinc anode plugs and see if these are ok. The gearbox oil and main heat exchangers are susceptible to dezincification if the zincs aren't maintained and replacements are scarce and uber expensive although it is simple to replace the gearbox oil cooler with an alternative such as Bowman at a fraction of the VP price.
    If you do buy it I have a host of manuals for the 40 series engines, just PM me and I will send you the links on Dropbox.
    Interested in Corvettes PM me for details of the Corvette Motorboat Association
  4. #14
    Join Date
    Jun 2001
    UK East Coast
    Posts
    1,855
    Quote Originally Posted by superheat6k View Post
    The 41P does not have any anodes in the cooling circuit and no problems of dezinc of the heat exchangers. Mine are 20 years old and all good - so far.......
  5. #15
    Join Date
    Mar 2008
    Posts
    137
    The small hatch at the forward end of the cabin gives good access to the water pump. There is just enough room to get an impeller removal tool between the pump and the aftermost battery.
  6. #16
    Join Date
    Jul 2019
    Posts
    25
    Quote Originally Posted by Plum View Post
    Cheers! I'll post results.
  7. #17
    Join Date
    Jul 2019
    Posts
    25
    That would be much appreciated, thanks.
  8. #18
    Join Date
    Jul 2019
    Posts
    25
    Quote Originally Posted by alancollins View Post
    Good news, cheers.
  9. #19
    Join Date
    Jul 2019
    Posts
    25
    Had a good look over the boat, all seems good. The engine looks clean, sounds very quiet and sweet and starts on the button without plumes of smoke. It does, however, continue to smoke at tick over when cold. Going out for sea trial tomorrow so hopefully will be ok once warmed up. Oil pressure around 80psi when cold at idle which seems a bit high. Any thoughts on a smokey cold idle?
  10. #20
    Join Date
    Jan 2012
    South Coast
    Posts
    5,202
    My specific experience is the TMD40A and TAMD60C. Does the gearbox cooler not have anodes either on the TAMD41P ?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
