Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Join Date
    Jun 2004
    Fareham
    Posts
    6,658
    Default Re: Plotter replacement
    Quote Originally Posted by JohnGC View Post
    Huh?
    Force 6+, choppy sea, slamming pitching and rolling. Hand steering and holding onto a plotter? Not for me.
    Sounds like you need to skill up too.
  2. #12
    Join Date
    Oct 2011
    Plymouth
    Posts
    719
    Quote Originally Posted by DJE View Post
    Sounds like you haven't actually been there
  3. #13
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,279
    Quote Originally Posted by gdallas View Post
    But rubbish in sunlight and sometimes a bit flaky; if for example the waterproof case gets very wet then it can be really hard to use the touch screen.
    An option if using charting SW on an Android tablet that is out of reach or wet is to buy a bluetooth android compatible mouse.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  4. #14
    Join Date
    Oct 2011
    Plymouth
    Posts
    719
    Quote Originally Posted by LadyInBed View Post
    I use one of these with my Windows system at the navstaton. It's not waterproof or rugged. But it works very well, no matter how much the boat bounces around. This particular one seems a bit flimsy although it has been fine.
    https://www.ebay.co.uk/i/15347517668...yABEgLItfD_BwE
  5. #15
    Join Date
    Apr 2015
    Troon
    Posts
    145
    Anyone got experience of using ONLY tablet nav? Is it really ok, robust, useable, visible?
    Yes. Done 6000 miles over the last 2 years using a 90 quid android tablet with a 20 quid bracket in the cabin (and a 60 quid one for backup) with dirt cheap VMH charts or Navionics. Chart plotters are nice, but for the cost I can have several flights out to Greece and a few meals thrown in!
  6. #16
    Join Date
    Apr 2002
    UK
    Posts
    887
    Interesting. Thank you. So maybe 2 tablets, one iOS and one Android, would give a decent level of redundancy and backup. I have a varnished mahogany cockpit with no permanently mounted instruments. I use a removable washboard which houses compass, sounder, and until recently a little SH plotter (now deceased). So I could have one of the tablets in some sort of housing on the washboard.
    Useful food for thought
  7. #17
    Join Date
    Apr 2015
    Troon
    Posts
    145
    Mine is in the cabin, but whatever you do, make sure it has a decent charging system, some tablets are not so good in daylight, so check before you mount it outside, The newer tablets such as iPad Pro will need a 2.4A charger rather than the usual 2.1A ones.
  8. #18
    Join Date
    Sep 2001
    Posts
    12,279
    You don't need a modern state of the art tablet to run nav sw, but it does need built in gps. I run OpenCPN on an old android Tab 2.
    It is worth fitting a 12v to usb charger like THIS so you can leave the tablet plugged in.
    MontyMariner.co.uk
  9. #19
    Join Date
    Jun 2016
    North West
    Posts
    558
    Navionics on a ten year old tablet has got me from the Isle of Wight to Cadiz so far, with no problems. I also have a Raymarine E7 (and usually, paper) in the cabin but it's just not as good as navionics on a tablet. The interface is clunky, I've only got the Imray raster charts on it because of the staggering cost of the Navionics vector charts.
    Regarding cost, you could always by 5 or 6 spares before you get anywhere near the price of a purpose built plotter and there are also water proof ones available. I just keep mine in a splash proof bag and it's been fine. If you get the thing properly clamped then it doesn't need to be fully ruggedised as it won't get whacked.
    Main problems, display brightness can be a challenge in bright sunlight and the charging cable can't actually charge it as fast as it discharges when on full brightness. But then it is an old tablet. Look for one with a USB-C connector as it carries more current.
  10. #20
    Join Date
    Mar 2002
    Greenwich
    Posts
    7,589
    Huh?
    Why do you need constant looks at a plotter - ours is an iPad kept on the chart table and only looked at every now and again
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
