Results 1 to 7 of 7
  1. #1
    Join Date
    Feb 2007
    Southampton / Chichester
    Posts
    450
    Default Volvo D1-20 Water Strainer Cracked
    Friend of mine has a 2006 Bavaria Cruiser 33 fitted with a 19hp Volvo D1-20. When he started it this Saturday the water intake was open but no water was coming out of the exhaust. On investigation the lid of the strainer had cracked the whole way around so you could remove the top of the lid leaving the threaded section behind. Any idea what could have caused this (he's always been careful not to over tighten it)? The boat sits in a drying mud berth and he's recently used a descaler suggested by the yard which you pour into the strainer with the lid off and the engine running and then switch off and leave for 24 hours. This improved the flow out of the exhaust which hadn't been great before (due to the mud berth maybe?) but now he has the broken strainer lid. Thoughts?
  2. #2
    Join Date
    Jan 2011
    Posts
    5,754
    Default Re: Volvo D1-20 Water Strainer Cracked
    Probably been over-tightened. Just replace it and get on with life.
  3. #3
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    20,447
    They always seem to be over-tightened. Even if you do them up by hand and try to just nip them up, the next time you try to remove them they are seriously tight again.
    I'm not surprised that eventually some of them crack.
    Richard
  4. #4
    Join Date
    May 2001
    UK East Coast
    Posts
    36,650
    Always coat the threads and O-ring with silicone grease before fitting the lid.
  5. #5
    Join Date
    Jul 2002
    Home: Kent. Boat: Chichester
    Posts
    43,614
    Quote Originally Posted by pvb View Post
    So that its easier to overtighten ?
  6. #6
    Join Date
    Feb 2008
    Suffolk
    Posts
    3,704
    Quote Originally Posted by VicS View Post
    So it's easier to get a good air tight seal...
  7. #7
    Join Date
    Nov 2009
    Southampton
    Posts
    35,609
    Heh. So that it's easier to undo, but yes, needs care not to overtighten since the torque required to do so is now less.
    I once snapped a wheel-nut stud by not appreciating this principle.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
