Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2019
    Essex
    Posts
    10
    Default Auxiliary engine for a Hardy pilot
    This may be wishful thinking but as I am buying a 2.3hp Honda for my tender, would it be of any use as an auxiliary engine on a semi displacement Hardy Pilot 20? I have seen 2.3hp Honda's used on yachts but their hulls are altogether different. Would it as an auxiliary be powerful enough to push my hardy home in an emergency. We would only be travelling up and down the River Blackwater, the Colne and Walton backwaters in Essex so never far from shore.
  2. #2
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,208
    Default Re: Auxiliary engine for a Hardy pilot
    If there is any sort of wind or current then your 2.3 will struggle, and you will have nightmares. Have you got any oars?
  3. #3
    Join Date
    Feb 2015
    Conwy
    Posts
    4,194
    I believe it will move the boat sure, but everything will be so slow to react that things like steering will become ineffective. i.e. not enough power to be useful on it's own with any certainty or reliability.
    EDIT
    Rafiki makes a good point. An oar lock on on the stern and suitable oar, then a combination of sculling and motor may just do the trick.
  4. #4
    Join Date
    Feb 2015
    Conwy
    Posts
    4,194
  5. #5
    Join Date
    Mar 2016
    Posts
    1,022
    It will have half a chance if the bracket it sits on allows it to have the prop in the free flowing water from under the hull. If it doesnít...then useless. Always a balance with this really as youíll likely know. All about the set up of the bracket. Too high and you get a complete loss of drive almost. Too low and it will almost certainly drag in the water when not in use. The ideal would be to have it well set up for your short shaft that you use on the dinghy. Otherwise itís of less use on the dinghy if you need to go to a long shaft.
    I get away with a 3hp Malta short shaft on the bracket of my 19ft cruiser. Pushes her along at about 4mph flat out and screaming. An easy 3mph at half to 3/4 throttle and civilised. Can use the main engine to steer even. Plus the Malta is a champ on the tender too. Being a short shaft.
    Good luck.
  6. #6
    Join Date
    Aug 2019
    Essex
    Posts
    10
    As I said it was wishful thinking but thank you all for your interesting comments.
    Another reason was finding a storage area on the Hardy for the Honda 2.3. The dinghy takes up all the space in the bow and I already have a 6hp Mercury on the auxiliary bracket which is too heavy for the dinghy.
    Thanks again.
  7. #7
    Join Date
    Dec 2001
    north ayrshire
    Posts
    465
    If your inland and dont mind slow why not give it a try. As said it will likely struggle against any wind and tide but it may keep you mobile as opposed to drifting helplessly even if you have to head in the general direction of wind and tide it will probably push you to somewhere safe to tie up or anchor untill you can sort yourself out/arrange a tow etc.
    Nothing to be lost by putting it on and trying it you may be pleasantly surprised
  8. #8
    Join Date
    Aug 2019
    Essex
    Posts
    10
    Thanks Beamishken, good point. I might just give it a try. (I see you enjoy "RIBnet" too)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
