Results 1 to 8 of 8
  1. #1
    Join Date
    Sep 2006
    London/SofF
    Posts
    1,522
    Default LED strip lights
    I would like to fit some LED strip/mini LED tubes in the ceiling of our cockpit
    On the roof of our cockpit there are recessed grooves that run in 3 rectangular sections. The picture shows one. The recessed grooves are 10mm wide and 2mm deep, and so I donít think I will get a perfect for, but want to use these as the pattern. Just warm white not trying to match Match!
    Any ideas?
  2. #2
    Join Date
    Aug 2017
    Posts
    29
    Default Re: LED strip lights
    Hi , there’s loads of different tapes available from various sizes and colours, obviously voltage also, main thing will be ip rating and where you can mount your driver,
    Have a look at the link for some ideas.
    https://arc-led.co.uk
  3. #3
    Join Date
    Mar 2004
    Posts
    6,072
    did something similar recently, the sideways curves did not bend too well and some of it wrinkled.
    perhaps cutting some V sections in the bends might have helped ?
    the blue leds are on the top only.
    bending up and down is no problem.
    Attached Images Attached Images
  4. #4
    Join Date
    Dec 2005
    Live London
    Posts
    3,843
    Getting the strip to flow round corners will be tricky.
    If you look up flexible neon on eBay there are ones that will bend but they are about 20-25mm thick so that wonít really work.
    Also do bear in mind that the the self adhesive backing is pretty poor and it wont last long. You will need a decent contact adhesive.
    All in the do that neatly I think will be a challenge. The strip should also be behind a diffuser as it will be on show and wonít look great.
    Sorry to have a down on it but it will be tricky !
  5. #5
    Join Date
    Mar 2007
    South of France.
    Posts
    4,147
    Ask Nick Burnham ... he's the LED expert! ……
    _______________________
  6. #6
    Join Date
    Sep 2006
    London/SofF
    Posts
    1,522
    I was hoping he might stumble across this and comment. I’ve seen his videos.
  7. #7
    Join Date
    May 2001
    Jersey/Antibes
    Posts
    22,638
    Shane I don't think you can put naked led strip in those recesses without it looking hideous. If the LEDs are not behind pelmet-type things to hide them, they need diffuser strips but it is massive job to fit those in your groove, especially with the corner radii. There is one exception I can think of: if (structurally) you can Fein-cut and/or rout a 3.5mm wide slot along the trough of those recesses then you could use this http://www.lightinginsight.com/produ...instripe-flex/ but you would need perfect execution especially around corner radii
    I would find somewhere else in the cockpit to fit a pelmet or utilise an existing pelmet type recess, and put LEDs there. Or fit recessed strips into the flat/plain parts of your ceiling panels. Or fit squares made of this (using some custom corner detailing) flat to the roof http://timage.eu/architecture/led-al...pin-strip.html
    Good luck!
  8. #8
    Join Date
    Sep 2006
    London/SofF
    Posts
    1,522
    All,
    Thanks for the input. I feel the great idea may have been born of too much champagne and will park it. It’s strange where the mind wanders when relaxing in the evening and you start thinking about things you might want to do to your boat.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
