Results 1 to 6 of 6
  1. #1
    Join Date
    May 2005
    Loch Snizort, Isle of Skye
    Posts
    4,921
    Default Tufnol- OK to use without any paint/varnish/etc?
    I've made up a plinth for a turning block, using two layers of Tufnol epoxied together. To achieve the correct shape it was sanded all over to round off the edges.
    It's no longer got that shiny finish on it now- all quite matt.
    Is it still OK to use it in an exposed location (coachroof) without any kind of sealer or other coating?
    Moody 39- Deb 33- Wayfarer- Wanderer
  2. #2
    Join Date
    Oct 2001
    Micheldever, hants
    Posts
    1,643
    Default Re: Tufnol- OK to use without any paint/varnish/etc?
    I have a big slab of tufnol that has stood outside in the elements for at least 4 years with no ill effects
  3. #3
    Join Date
    Aug 2004
    Cumbria; U.K.
    Posts
    3,303
    Barton make/ (made?) lots of fittings, blocks, winches etc. from Tufnol. Lasts for years.
  4. #4
    Join Date
    Jun 2019
    Scarborough
    Posts
    618
    I have some very old tufnol blocks, big ones holding up the boom etc, I completely leave them alone and they are fine, any coating could not make them better, but it might have some dodgy chemical reaction if you are unlucky..so I say, leave well alone!
    "Now shall the gentleman haul and draw with the mariner"
    John Hawkins
  5. #5
    Join Date
    Dec 2007
    S.W. France
    Posts
    7,678
    Be a bit careful with the breathing the dust, not good for you. Otherwise, as above, no coating needed.
  6. #6
    Join Date
    Nov 2001
    Posts
    4,160
    If you want them shiney just give them a coat of varnish. Tufnol is virtually indestructible.
    Donald
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
