Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2001
    Me: Johannesburg South Africa Yacht: Richards Bay East Coast Africa
    Posts
    7,123
    Default Replacing fender valves.
    There was a post a little while ago about replacing valves in fenders which I read with interest
    Hoving some fenders with valve missing I was wondering if anyone has tried to replace the valve with a tubeless tire valve by cutting it down and gluing it into the existing hole or by enlarging the existing valve.
    If so what kind of glue my thinking is either sikaflex or the like or as the fenders tend to be made from PVC some PCV weld glue as used with PVC piping/conduit.
    Life is too short not to have a sea view
    Distantshaws tinyurl.com/yclt6l68
  2. #2
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    10,330
    Default Re: Replacing fender valves.
    I've no idea what glue to use for this, but I'd be a bit leery of having a valve sticking out of the fenders in case it damaged the gelcoat
    Steve
    Never believe anything until it has been officially denied.
  3. #3
    Join Date
    Mar 2004
    Posts
    6,066
    drilled mine out and sikkaflexed the new ones back in, worked just fine, nothing sticking out
    you can sort the alignment with a bolt that inserts into the valve to guide it, perfect
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
