Results 1 to 6 of 6
  1. #1
    Join Date
    Jan 2008
    Moor & Dock- Leros
    Posts
    459
    Default Waeco CU 84 Thermostat problem?
    We recently got back to our Bav 39, in Greece and find the fridge is cooling, but the compressor is running most of the time, even at night when itís reasonably cool. Iíve turned the Thermostat to its warmest setting and itís still cooling and still running most of the time, so I think itís a Thermostat problem.
    Is there any way to check if the Thermostat operation?
    Where is the Thermostat Probe fitted on these fridges?
    Thanks,
    John
  2. #2
    Join Date
    Mar 2018
    Posts
    311
    Default Re: Waeco CU 84 Thermostat problem?
    You need a re-gas.
    The thermostat’s probe is inside the evaporator.
  3. #3
    Join Date
    Aug 2004
    Posts
    4,671
    Quote Originally Posted by XDC View Post
    You need a re-gas.
    Plus 1 on this. If the compressor is running all the time then the box should freeze up if the compressor is working properly. There are some 'work around' thermostat problems ( on line) using cheap sensors and digital gauges but the bet is on the compressor.
  4. #4
    Join Date
    Jan 2008
    Moor & Dock- Leros
    Posts
    459
    Thanks for the steer- you’re both correct. I had it re-gassed earlier and everything is fine.
    Thanks again,
    John
  5. #5
    Join Date
    Jan 2012
    South Coast
    Posts
    5,196
    Did you find the leak ?
    If not lather, rinse, & repeat this thread in 1 / 3 / 6 months.
    Leaks do not go away just because you re-gas the fridge.
    Interested in Corvettes PM me for details of the Corvette Motorboat Association
  6. #6
    Join Date
    Jan 2008
    Moor & Dock- Leros
    Posts
    459
    We didn’t find the leak, but it is 5 years since it was last re-gassed.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
