Re: Going up the mast (solo) and what to expect at the top...
A really interesting thread. On our present boat we have fold away mast steps which I would recommend to the OP. For others who, like a previous contributor, are winched up by crew/wife/skipper/etc. there is an easier way, without climbing equipment. Main halyard tied onto a bosun's chair and down to a winch, via a clutch, hopefully in the cockpit. Tie a loop into another halyard or in our case the topping lift. Then simply climb the mast by putting your feet in the loop and each side of the mast. When you are standing up on the loop, your assistant tightens the halyard, then sit in the chair and they can tighten topping lift. In our case the halyard is led from the coachroof winch to the genoa winch and locked while i'm working at the masthead. We still do this now I can use the steps. I have no problem with the height but my partner would have a big problem winding 110kg of me up the mast.
Allan
Sailblogs.com search Brilliant with Hilary and Allan as crew. Password Bristol.
Bookmarks
