Results 1 to 8 of 8
  1. #1
    Join Date
    Oct 2019
    Posts
    3
    Default Williams 325 - Fuel Pump issue
    Hello,
    I do have the following problem with my 2007 Williams 325 tender.
    8 weeks ago I recognized that when I wanted to start the tender the Fuel Pump doesnít do anything anymore.
    The Relais works but fuel pump doesnít start to take the fuel.
    Went to local Williams dealer here in Mallorca and bought a new fuel pump - built in - everything worked fine.
    Now the tender was not in use for a few weeks and when I did a trip to Ibiza with my boat the 325 did not work the same way. Bought a new fuel pump at Williams Ibiza - everything worked fine.
    Now, after 8 days the fuel pump doesnít start anymore as well - and I am now clueless and donít think that the fuel pump does always blew off.
    Does anyone have a hint in that case ?
    Elecriticy on, turn the ignition key, Relais works, fuel pump doesnít do anything.......
    Thanks in advance for any kind clue.
    Best regards,
    Stefan
  2. #2
    Join Date
    Dec 2005
    Live London
    Posts
    3,831
    Default Re: Williams 325 - Fuel Pump issue
    The pumps are standard items on eBay for next time!
    https://www.ebay.co.uk/itm/HIGH-POWE...cAAOSwt5hYd6w2
    The first thing is to put 12 volts across the pump and see if it runs. If so then there is another problem. If not then you have been unlucky a few times in a row ( unlikely I accept)
    Bear in mind that if the kill switch is pulled off or not making contact then the fuel pump will not run. These switches have a limited life so I would check that first. In the short term you can short it out - but for the sake of you and passengers don't leave it like that.
    If not that then I would go through the rib pulling and cleaning each connector and covering it in WD40
    Finally whilst I doubt it is the issue I would make 100% sure the battery is fully charged.
    From memory ( and it is only from memory so could be wrong) the pump pressurises the rail. There is a I think a pressure switch that then cuts in to stop the pump. It could be that. I will try and look later to see if I am right or it was just my imagination.
  3. #3
    Join Date
    Oct 2019
    Posts
    3
    Checked the first pump and that seems to be broken.
    The second pump I didnít check until now.
    The killl switch works, checked 5 minutes ago and the Williams went well with the actual pump until 4 days ago. When I wanted to flush it yesterday the pump didnít say a word anymore.
    Will check the connectors tomorrow, battery is full charged.
    If there is a pressure switch would be interesting to know where, as I could be that one. Canít believe to have bought two fuel pumps with production failures or else.....
    Thank you very much for your fast answer as I am satisfied with the 325 until now. Beside it sits also on a Squadron 58 like yours I think.
    Best regards,
    Stefan
  4. #4
    Join Date
    Apr 2007
    Mallorca
    Posts
    610
    I think you will find that there is contamination in the fuel tank. The aluminium tank can corrode inside leaving a sandy kind of powder in the bottom. The fuel filter is after the pump. Fit a decent fuel filter before the pump and it should sort it.
  5. #5
    Join Date
    Dec 2005
    Live London
    Posts
    3,831
    Quote Originally Posted by aquatom View Post
    The tanks on both of mine have been plastic.
  6. #6
    Join Date
    Apr 2007
    Mallorca
    Posts
    610
    Iím sure the earlier ones were aluminium
  7. #7
    Join Date
    Jun 2010
    Home staffs Boat Mallorca
    Posts
    296
    Yes our 2008 is aluminium tank
  8. #8
    Join Date
    Oct 2019
    Posts
    3
    My tank is also a plastic one.
    Went to Williams and asked to change the pump for guarantee as only some weeks old.
    They told me that the problem is with the minor quality of the petrol. They have checked that the 98 octane petrol has only 81 octane petrol and that’s one of the reasons.
    Also recommended to take the petrol from the car station instead of the harbour.....
    What should a simple fuel pump do with octane numbers ? Doesn’t matter at all for me.
    When I have to fill up the tender on the car station or handling the petrol of it I have the wrong dinghy.....
    Nevermind, they changed the fuel pump without any costs - but will check now if there are not any „maybe“ better fuel pumps around. I also thought about installing a water absorber ?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
