Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Join Date
    Jan 2005
    Hampshire
    Posts
    845
    Default New engine but which oil......
    I've seen a few threads about engine oil over the years and have been comfortable with what to put in my old Thorneycroft engine.
    Now I have purchased a shiny new engine (Sole 42 - Mitsubishi based), I have the following oil recommendation to meet: ACEA E5/E3 or API CH-4/SJ grade 15w40
    The service intervals quoted by the manufacturer is 250Hrs (which feels uncomfortably long on a boat engine...) so I am keen to use an oil that is likely to last this long.
    - Any recommendations of make/Type? It's a bewildering range of choices.......
    Thanks.
    Work is for people who don't know how to sail!
  2. #2
    Join Date
    May 2001
    North Wales, sailing Aegean Sea or Menai Strait
    Posts
    22,068
    Default Re: New engine but which oil......
    Select any big name manufacturer. All will have gone through stringent industry tests and will be totally satisfactory.
    Answers to some technical queries at new website http://coxeng.co.uk
  3. #3
    Join Date
    Jan 2012
    South Coast
    Posts
    5,240
    As Vyv says - just look for the 15W40 bit, semi synthetic would be my choice. I use this stuff in my Cummins 6BT5.9M (Thornycroft), but mainly because it was free from a client who used the stuff in there emergency supply generators..
    Duron HP 15W40
    Shell Rimula R4 15W40 is another popular choice.
    The API standard CH4 is a laid down standard, so the make doesn't really matter, as long as the oil complies with this standard.
    From Google search - took around 4 seconds to find
    CH4 - Current - Introduced in 1998. For high-speed, four-stroke engines designed to meet 1998 exhaust emission standards. CH-4 oils are specifically compounded for use with diesel fuels ranging in sulfur content up to 0.5% weight. Can be used in place of CD, CE, CF-4, and CG-4 oils.
    Be aware most Thornycroft were simply a name applied to someone else's engine once marinised.
    Interested in Corvettes PM me for details of the Corvette Motorboat Association
  4. #4
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,875
    Mine is most likely the same engine (Mitsubishi S4L) but marinised by Thornycroft, it's old tech and Thornycroft specified mineral oil. Mitsubishi manual specifies CD grade, which is obsolete. https://www.manualslib.com/products/...l-4028224.html
  5. #5
    Join Date
    Feb 2008
    Suffolk
    Posts
    3,735
    On my Beta 25, Kubota based, I was told it must be a Mineral oil 15w40. Engine seems fine after over 1000 hrs, never uses any oil between annual changes.
  6. #6
    Join Date
    Jan 2005
    Hampshire
    Posts
    845
    Thanks all that replied.
    Google had already shown those items however, I am still undecided about Mineral Vs Semi-synthetic. I have read a lot of the prose on here and other places but it seems that it's a personal choice rather than any overwhelming technical fact.
    I'm slightly nervous at going 250Hrs between oil changes - does anyone else leave it that long?
  7. #7
    Join Date
    Sep 2017
    Posts
    1,854
    Quote Originally Posted by Piddy View Post
    250 hr equates to approx 10k mls in a car, if thats any help
  8. #8
    Join Date
    May 2007
    Posts
    38,896
    Quote Originally Posted by PetiteFleur View Post
    Gen-yew-whine Kubota own brand oil appears to be CI4 CH4 ACEA E7 FWIW
    Q: Can I use synthetic oil in my Kubota engine?
    A: Kubota recommends oil with an API rating of CF or higher. If the synthetic oil meets those standards, it can be used in Kubota engines.
  9. #9
    Join Date
    Nov 2001
    scotland
    Posts
    3,448
    P
    I fully understand why you might be concerned at leaving oil change to what is possibly 5 years
    Does the book not have X hours or Y years
    Perhaps I am old fashioned but oil and filters each year as a minimum seems right despite what the book says
  10. #10
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    21,116
    Quote Originally Posted by Old Harry View Post
    Probably even less than 10,000 miles ..... and my diesel car has manufacturer oil change every 25,000 miles which would be over 800 hours in a boat.
    250 hours between oil changes using synthetic oil would be throwing away oil in virtually new condition unless seawater is finding it's way into the sump. However, your metal to metal friction surfaces would last forever under such a regime.
    Richard
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
