Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Dec 2005
    Live London
    Posts
    3,843
    Default Re: Wrapping the perspex of a bow hatch
    I have gone the other way.
    I have ply fabric covered blanks for the port holes to no need for curtains or blinds which is much nicer. As such I rarely remove the port hole covers and use the top for all light
  2. #12
    Join Date
    Jun 2005
    Posts
    316
    Quote Originally Posted by vas View Post
    ...and to be helpful, how about doing a cloth cover, with a seam all around and a vertical part of a few cm with a strongish rubber band inside so that it wraps over and stays?
    Like this? https://www.force4.co.uk/hatch-cover.html
  3. #13
    Join Date
    Apr 2008
    Isle of Man
    Posts
    2,114
    Quote Originally Posted by TheOrs View Post
    I bought one of those.....useless. If you pull it tight with the lid open, it then sits on the seal and lets water in. If you pull it tight with the lid closed, the edge is thick and hardly tucks under the hatch lip.
    I had proper covers made on my current boat with poppers onto the deck. Problem solved
  4. #14
    Join Date
    Feb 2006
    Posts
    6,369
    There you go get the sewing machine out.
    https://www.sailrite.com/How-to-Make...ch-Cover-Video
  5. #15
    Join Date
    Mar 2002
    Posts
    17,661
    Quote Originally Posted by BruceK View Post
    I may not be understanding of what you mean by sliding panel as I don't have such.
    Sorry, in hindsight I appreciate that I was referring to the ceiling arrangement in my boat, which was actually custom built by the yard.
    But one way or another, I've always seen bow hatches with some sort of internal blind, either rolling or sliding.
    This arrangement is sort of irrelevant, though - what I'm after is a way to darken the perspex permanently, making the internal blind redundant, so to speak.
    Anyhow, below is a pic of my current setup, just for the records.
    Thanks everybody for all other suggestions, but I still think that an external wrapping is the easiest route.
    After all, it wouldn't be a big deal to replace it every few years, if need be.
    In the meantime, I also saw that there's plenty of wrapping films for sale online, also with some colours choice.
    But if anyone can recommend a specific type/brand, I'm all ears!
  6. #16
    Join Date
    Apr 2008
    Isle of Man
    Posts
    2,114
  7. #17
    Join Date
    Nov 2012
    Ireland / Sant Carles de la Rapita
    Posts
    218
    Hi, use Oracal Cast Vinyl wrap.
    It is 7 years design and breathable application. Needs heated to correct temperature with an airgun to lose its memory shape, so properly applied is important.
    I've used it very successfully in the med sun on my boat, even on hardtop with no colour fade etc. Quick wash, like new.
  8. #18
    Join Date
    Dec 2003
    Posts
    108
    You might want to consider an "etched" material. This gives an effect similar to an old fashoined pub / shop window.
    It does not give a totally obscure black out effect. But will cut the glare from bright early morning sun.
    We used to supply precut panels to Fairline (eg SQ62) using this material.
    The Fairline ones were I think applied on the inside of the hatch glass. Depending on where your hatch is, if applying on the outside, potentially the main source of wear and tear will be deck shoes walking on it not the weather.
  9. #19
    Join Date
    Mar 2002
    Posts
    17,661
    Deck shoes!?
    Here in the Med, keelhauling is standard practice, for anyone who dares boarding with anything else than bare feet!
    Thanks for the additional suggestions, folks. I will check out those brands/types to make up my mind...
  10. #20
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    16,550
    Quote Originally Posted by MapisM View Post
    Deck shoes!?
    P, Malcolm2 (post #18), is the man for these things. If I remember correctly, he was wrapping trains and jumbo jet tails (much to Margaret Thatcher's displeasure) with vinyl decades ago.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
