Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Join Date
    Nov 2004
    fareham hampshire
    Posts
    1,723
    Default Re: French canals Calais to the Mediterranean
    Quote Originally Posted by Jeannius View Post
    Took a rented Le Boat Horizon 2 the length of the Canal du Midi and the Canal d Garonne earlier this year. Stated air draft is 2.90 m with a beam of 4.2 m. It was very, very tight on a few of the bridges (made contact with the lowest, Capestang). This thing was almost as wide at the top as at the waterline so tricky through a lot of bridges.
    You would probably not get through Capestang with 3.5m air draft unless you are quite narrow up high. It's a long way back though if you get it wrong!
    Obviously they did not take flybridge boats into consideration when building it
  2. #12
    Join Date
    Nov 2009
    Kent
    Posts
    84
    [QUOTE=oldgit;6935602]will have look at that myself .
    Modify your search Search results
    Main routes
    Either your journey is too long (please reduce the distance between the departure and arrival ports).
    Or it is impossible by fluviale water
    I found that it can't cope with too long distances. You therefore need to break it up in shorter bits so you still need an overview map to see the various options. Still a good tool though and it is free!
  3. #13
    Join Date
    Nov 2001
    Medway
    Posts
    19,969
    Quote Originally Posted by stelican View Post
    Probably the same outfit daft enough to build the castle at Windsor just down the road from a noisy airport ?
  4. #14
    Join Date
    Jan 2011
    Dorset
    Posts
    502
    Broom owners club..... www.broomowners.com
  5. #15
    Join Date
    Nov 2001
    Medway
    Posts
    19,969
    ...possible onward journey is merely a thought at present. "Plan" is to be going over to Dunkerque in May for the evacuation commemorations. and after that ?
  6. #16
    Join Date
    Nov 2004
    fareham hampshire
    Posts
    1,723
    Quote Originally Posted by oldgit View Post
    I believe there is a plan to dig out the riverbed at the bridges with low headroom problem solved
  7. #17
    Join Date
    Sep 2016
    SoF
    Posts
    9,809
    Can I say that it’s not all sedate waterways. The mighty Rhone at full flow is a very scary thing But nonetheless many many people do it! While I’ve never done a full joined up trip, I have done a few canals and I will say, they are all incredibly beautiful and interesting
    Neither a Leaver or Remainer be
  8. #18
    Join Date
    Oct 2019
    Posts
    4
    Hi thanks for reply,what was your air draft?
  9. #19
    Join Date
    Sep 2016
    SoF
    Posts
    9,809
    Quote Originally Posted by prento1 View Post
    Well, I don’t remember. It was a 43 ft flybridge but it was made for the hire companies on the canals. I can tell you that we had to duck for every bridge and some (especially on rivers) were real squeakers. Unless you were tied up for a while it was never worth putting up the Bimini, even in the height of summer
    Ps. Some of the many many locks are deep and scary. Make sure you and your spouse aren’t claustrophobic
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
