Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    10,369
    Default Outboard Replacement
    My faithful Tohatsu 3.5 was stolen over the weekend, so I need a replacement.
    Its main use will be going a few hundred metres to the mooring and back, plus pottering around places like Newtown Creek and Chichester Harbour, pushing a 2.3m flubber. The old engine wouldn't quite get it on the plane, so I'm guessing that going down 1 hp wouldn't be a huge disadvantage
    It seems that I have 4 options
    1. Bite the bullet and buy a new 2.5-3.5 hp 4-stroke
    Advantages - No mixing fuel, warranty, reliability (I hope!). Air cooled could mean no need to flush after use, but noisy?
    Disadvantages - Expensive - pushes my budget close to breaking point, heavier than a 2-T
    2. Look for a second hand 2.5 - 3.5 2-T
    Advantages - cheaper, lighter
    Disadvantages - Unknown history and reliability, but could get a limited warranty from a dealer.
    3 New electric OB
    I know next to nothing about them, except that the Torqeedo range is way too much for me. Minn Kota and others are a lot more reasonable, but I presume I have to add a battery and a box to protect it. Any recommendations? What thrust would I need, and how much use can I expect from a battery that I'd want to carry, say, 85AH, so ~30AH usable to get a good number of cycles?
    Your thoughts, comments and criticisms of my reasoning, please
    Steve
    Never believe anything until it has been officially denied.
  2. #2
    Join Date
    Oct 2018
    A Member State of the European Union
    Posts
    6,568
    Default Re: Outboard Replacement
    Not what you had in mind but if you had a well-shaped rigid dinghy, rowing those distances would be not be a hardship.
    "Brexit: like watching a library being burned down by people who can't read"
  3. #3
    Join Date
    Oct 2002
    Plymouth
    Posts
    8,619
    "2. Look for a second hand 2.5 - 3.5 2-T
    Disadvantages - Unknown history and reliability, but could get a limited warranty from a dealer."
    Did you notice, Steve66 has a couple available in the For Sale section?
  4. #4
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    20,461
    In a similar situation 5 years ago I bought a Suzuki 2.5 4 stroke. Light, quiet, reliable and economical.
    5 years later it still starts first pull every May, having being left in a locker since September the previous year.
    Only three caveats 1) fit a cheap inline filter, 2) drain down the carb through the easily accessed plug when leaving for several months, and 3) stick in a waste bin (I use an old cut off fender) and flush with fresh water before draining the carb.
    Richard
  5. #5
    Join Date
    Mar 2015
    Posts
    1,007
    Honda 2.3 every time. Air cooled and lovely-to-use centrifugal clutch. Unless you’re the sort of person that actually will flush your water cooled OB in fresh water after each use. In that case, go with Richard’s recommendation.
  6. #6
    Join Date
    Dec 2012
    Fortrose
    Posts
    1,568
    Honda 2.3. I've one for a very similar use as you, and would do a 'like for like' replacement were a scrote to have it away,
    Folkboat 'Stakkr' - Inverness - http://islandrov.wix.com/island-rov-web
  7. #7
    Join Date
    Jul 2009
    South Wales and Bristol Channel, UK
    Posts
    2,510
    I have a Tohatsu 3.5 four-stroke and a Suzuki 2.5 four-stroke, I also had a Honda 2 hp. The Honda was good and light and the centrifugal clutch was very convenient; the Tohatsu is a bit heavy but very robust.
    The Suzuki is very light (as light as a 2 stroke) and so far very reliable and has plenty of power; also, accidentally I left the Suzuki, the wrong way down for many hours and to my surprise the oil did not migrate to the carburettor and the engine started on first pull without any smoke from the exhaust.
  8. #8
    Join Date
    Dec 2005
    2018/19 Floating west in the Pacific
    Posts
    2,231
    Can you still buy new 2-strokes in the Channel Islands?
    Hit the road often enough and eventually it will hit you back.
  9. #9
    Join Date
    Sep 2001
    S. Wales
    Posts
    241
    probably on the wrong forum but my Mariner 3.5Hp 4 stroke is excess to requirements - I've had it from new and bought a Torqueedo to prevent severe tennis elbow recurring! Works fine unlike my elbow, would accept a reasonable offer! Am based in S Wales & Dartmouth
  10. #10
    Join Date
    Apr 2018
    Mooring, Faro
    Posts
    1,711
    Quote Originally Posted by BobnLesley View Post
    http://mainbrayce.co.uk/two-strokes-still-available/
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
