Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Radar Cable
  1. #1
    Join Date
    Mar 2005
    bromsgrove, worcs
    Posts
    155
    Default Radar Cable
    Hi, anyone know the gauge (AWG) of the tiny wires in a Raymarine radar cable ?. Thanks Phil
  2. #2
    Join Date
    Nov 2009
    Southampton
    Posts
    35,680
    Default Re: Radar Cable
    Which radar? The old analogue ones, first generation digital with proprietary cable, or current models with ethernet?
  3. #3
    Join Date
    Mar 2005
    bromsgrove, worcs
    Posts
    155
    Hmm, 2009 .. first gen digital? I'll check the manual when on board.
  4. #4
    Join Date
    May 2016
    Suffolk
    Posts
    8,160
    Quote Originally Posted by PTB View Post
    2009 could well be ethernet cable, what do the connectors look like, what's the plotter ?
    Oh, why do you ask ?
    Rainbow Marine.
    www.rainbowmarine.co.uk
  5. #5
    Join Date
    Jan 2016
    Southwold & Ipswich
    Posts
    1,502
    Have you snipped it
    Electrical & heating engineer, Diesel remaps, Custom panels
    Southwold & Ipswich Yards
  6. #6
    Join Date
    Mar 2005
    bromsgrove, worcs
    Posts
    155
    Its an RD218 scanner to a C120 plotter. In fitting a new jack stay attachment I have drilled right through the middle of the radar cable. What an idiot. Anyway, I am looking for connector options to make a joint. For example, wondering if wago do anything for wires so small.
  7. #7
    Join Date
    May 2001
    UK East Coast
    Posts
    37,064
    That's an "Ooops"! You need something waterproof; Wago connectors aren't. I'd be tempted to take the cable out and use solder and heatshrink to repair the damage.
  8. #8
    Join Date
    May 2016
    Suffolk
    Posts
    8,160
    The only really reliable way to put that right would be to solder and individually glue lined heatshrink each wire, with glue lined heatshrink over the whole repair.
    Rainbow Marine.
  9. #9
    Join Date
    Mar 2005
    bromsgrove, worcs
    Posts
    155
    Thanks for that ... another winter job now specced up. P
  10. #10
    Join Date
    Nov 2009
    Southampton
    Posts
    35,680
    Did you sever the whole thing, or just nick it and damage the "tiny wires" (which aren't really all that tiny, honestly)? Be aware that one of the other cores is a co-ax cable with its own screen and dielectric, and needs to be repaired accordingly.
    Agree with Paul and pvb about the repair method, though I'd consider the glue-lined optional on the inside. Normal heat-shrink is sufficient to insulate the cores from each other, and you shouldn't be getting water inside the cable. Make sure the outer sleeve (very definitely glue-lined) has a substantial overlap with the original cable sheath, and shows a neat, even extrusion of glue right round the end.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
