Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Mar 2019
    Posts
    219
    Default Lowering level of fore peak sleeping platform - is this a bad idea?
    Hi folks
    We spend a lot of time on our boat,about 60 nights this year.
    The forepeak is good to sleep in but to make it a bit comfier I was thinking of lowering the sleeping area (to where yellow line is in photo).
    Is there any major reason I shouldn't do this?
    We would lose the storage which is there now and the sleeping area would be a bit narrower but we would have more head room and wouldn't have the clambering in and out thing.
    I could keep all the materials removed so that it could be converted back in the future.
    Any thoughts would be appreciated
  2. #2
    Join Date
    Oct 2002
    Plymouth
    Posts
    8,713
    Default Re: Lowering level of fore peak sleeping platform - is this a bad idea?
    Depending on the shape of your boat the reduction in length might be quite dramatic.
    You could probably sight a laser level forward to give you a good steer on this.
  3. #3
    Join Date
    Sep 2017
    Posts
    1,858
    Quote Originally Posted by doug748 View Post
    Also the width will undoubtedly narrow too
  4. #4
    Join Date
    Mar 2005
    Hants/Lozère
    Posts
    4,836
    It might be easier to add a step (or two) to improve your clambering in and out. Why do you need extra headroom when you're lying in the bunk?
  5. #5
    Join Date
    Nov 2011
    Sydney, Australia.
    Posts
    5,605
    Quote Originally Posted by Hoolie View Post
    IWhy do you need extra headroom when you're lying in the bunk?
    It will be interesting to read the reply
    Jonathan
  6. #6
    Join Date
    Mar 2019
    Posts
    219
    Yes would obv have less length and width but it would still be plenty even with it lowered
    I think a step would get in the way of the other doors opening.
    Jonathan - laughed at that one!
    Hoolie, I guess we don't need the extra headroom - but we're still in our 30's ;-)
    I'll have a think about it
  7. #7
    Join Date
    Jul 2009
    North Bucks
    Posts
    790
    As you get older clambering up into the forepeak sleeping area becomes more difficult, a folding stool/step from ebay for less than £10 proved very stable and solved the problem for us. Easily folded or moved if it blocks access to one of the doors
    Andrew
  8. #8
    Join Date
    May 2003
    SPAIN,Galicia
    Posts
    12,868
    In Spain we have double beds then we have “carinosos” meaning smaller for people who really like each other though they are not pointed at the end!
  9. #9
    Join Date
    Nov 2009
    Bristol
    Posts
    566
    If the length of the bunk is shortened then I'd mock up a template of the size post drop. Then imagine sleeping in that space for however long you go sailing for.
  10. #10
    Join Date
    Feb 2010
    Bristol
    Posts
    2,149
    Check that your boat hasn’t been designed with the top of the v berth purposely above the waterline and made as a sealed bulkhead. My forward cabin is like this and If holed at the bow then the lockers in the V berth could flood. Providing the boat is stopped and water isn’t being forced in through the hole then technically it shouldn’t spill over into the rest of the boat.
    Mine has the additional protection of the lockers in the V berth being sealed well with neoprene gaskets. On top of that my entire forward cabin is a sealed bulkhead from the rest of the boat. Anyway if the forward V berth is above the waterline and sealed off from inside .... I.e gelcoated inside..... then it may have been designed with safety in mind.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
