Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1
    Join Date
    Nov 2004
    Northamptonshire
    Posts
    1,894
    Default Diesel heater exhaust
    I'm about to install a diesel heater on my boat, can the exhaust skin fitting be positioned above the height of the heater? The location I'm thinking of would have the skin fitting about 30cm above the heater. Would the exhaust require a swan neck too?
  2. #2
    Join Date
    Jun 2009
    Posts
    12,531
    Default Re: Diesel heater exhaust
    Ours (Webasto) certainly is - by a good couple of feet. We didn't fit it - it was done professionally by a Webasto main dealer - so I cannot comment on the details of the installation.
  3. #3
    Join Date
    Mar 2004
    Posts
    6,099
    my exhaust is at least 30cm above the heater, with a swan neck, as described in the manual.
    you don't want sea or rain water going down the exhaust.
  4. #4
    Join Date
    Jul 2012
    Jersey
    Posts
    794
    Quote Originally Posted by simonfraser View Post
    ... or condensate.
  5. #5
    Join Date
    Jun 2009
    Posts
    12,531
    Quote Originally Posted by Keith-i View Post
    ... or condensate.
    Indeed - but having the exhaust above the heater makes that more likely.....
  6. #6
    Join Date
    Feb 2008
    Farndon
    Posts
    3,134
    My Eberspacher has a condensate drain of the metal elbow part of the exhaust and the exhaust outlet is above the heater .
    . https://www.butlertechnik.com/instal...92199005687-p4
  7. #7
    Join Date
    Jun 2001
    UK East Coast
    Posts
    1,904
    Quote Originally Posted by SimonA View Post
    Mine is 30cm above water on the side of the boat and is above the Eberspacher. My skin fitting is the angled type so the exhaust tube has a loop about 80mm above the skin fitting with the last 200mm of the tube downhill to the angled skin fitting. Been ok for 5 years.
    www.solocoastalsailing.co.uk
  8. #8
    Join Date
    Aug 2015
    Posts
    246
    I've had to fit my exhaust higher than the heater and as a consequence rain water collected in the silencer and pipe.
    Simple solution was to fit an expanding hung when not in use....
    The hull fitting is straight through not the angled version
  9. #9
    Join Date
    Jun 2017
    Posts
    234
    Mines about level with the heater. No issues in 18 yrs
  10. #10
    Join Date
    Mar 2016
    Posts
    1,064
    It needs to be higher really. Also states this very clearly in manual
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
