Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Join Date
    Oct 2018
    Posts
    90
    Default 42' boat Propeller Repair need help.
    My 42' boat starboard side propeller hit on a rock last year in the coastal area. It cause a cure on one piece of the propeller. So now it has unbalance vibration if it run over 1000 rpm. Any suggestion on how to fix it? Many thanks!
  2. #2
    Join Date
    May 2001
    Posts
    15,719
    Default Re: 42' boat Propeller Repair need help.
    It will have to be sent to a prop repairer. Where are you and the boat?
  3. #3
    Join Date
    Oct 2018
    Posts
    90
    I and the boat are in Shepperton, Surrey.
    It is possible to remove the propeller from under water? Or do I need to put the boat on land to do that?
  4. #4
    Join Date
    Oct 2003
    west yorkshire
    Posts
    4,295
    you will have to lift the boat out and block it up. Props can be difficult to get off especially if they have been on a long time.
    Patience, ideally some sort of prop puller and heat usually does it.
  5. #5
    Join Date
    Oct 2018
    Posts
    90
    Then I might have to make a plan for any other items need to be fixed or check under the bottom. And try to make it back to water ASAP.
  6. #6
    Join Date
    Oct 2001
    Surrey & boat in Dorset. Both have pubs
    Posts
    3,845
    Quote Originally Posted by Lucas Gan View Post
    Theres a prop repair company called Steel Developments in Wandsworth. Been there for years.
    https://www.steeldevelopments.net
  7. #7
    Join Date
    Aug 2016
    East Coast UK
    Posts
    55
    T A Norris Borehamwood
  8. #8
    Join Date
    Jun 2004
    Guernsey
    Posts
    3,093
    I assume the prop is on a Shaft ?
    If the prop has a decent ding in it, its possible the shaft is bent especially the taper at the prop end, so you may need to remove it for inspection or checking in a lathe.
  9. #9
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,244
    Quote Originally Posted by Boathook View Post
    Ive used Steel Developments several times and always delighted with the service and value.
  10. #10
    Join Date
    Oct 2018
    Posts
    90
    Many thanks mates.
    The Shaft is straight. Just the propeller has one blade bend. I saw it during last year transport.
    I am thinking maybe found the way to remove the propeller from under water will be great. That might save a lot money for lift up the boat and stand on land. Is there any under water removal service around?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
