Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Pershing
  1. #21
    Join Date
    Mar 2002
    Posts
    17,757
    Default Re: Pershing
    No need to go to SoF to answer the OP question, Porto.
    Pershings are made in IT, so it's pretty obvious that quality wise they are better than Prin or Sskr.
    Bye now, must go look for my coat......
  2. #22
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,441
    Quote Originally Posted by MapisM View Post
    Glad you said it I was trying to work round it .
  3. #23
    Join Date
    Jul 2017
    Leeds
    Posts
    60
    Looks like I need to jump on a plane and check one out.
  4. #24
    Join Date
    Nov 2019
    Posts
    3
    I have heard some "expert" at a yacht show say that Pershing is no good for a slow cruise speed (of 10-12 knots) that it's only good for cruising at very high speeds (which eats up a lot of fuel) or to go very slowly, but not for a cruise/pleasure speed. Is that a fair judgement? Because of this I have been passing on some Pershing options, but some of them have decent interiors and if the cruising speed argument is not true, I might consider those more seriously. Thanks
  5. #25
    Join Date
    Mar 2002
    Posts
    17,757
    Well, it doesn't take any expert to expect a boat designed with a 50 knots capability in mind to be less than ideal for 10kts cruising!
    This is actually true of any planing boat, but even more so of the faster ones.
  6. #26
    Join Date
    Jul 2017
    Leeds
    Posts
    60
    Quote Originally Posted by JohnSmith1234 View Post
    I was under the impression, if fitted with Arneson drives, they are more economical than shaft boats.........but a real pain to manoeuvre.
  7. #27
    Join Date
    May 2007
    Malta - Med Sea
    Posts
    3,679
    Manovring
    They are like shaft drives but have a stronger thrust. They are not as bad as stern drives in manovring.
    Consumption
    Actually at high cruise speeds (25/30 knots or more) a surface drive boat is more efficient to a similar sized and weight shaft drive boat (usually about 10 to 20% more efficient).
    The more the speed the more efficient they are. The important note is for a surface drive boat not to be under-powered.
    At 10 knots consumption would be the same as a shaft drive boat, they will consume more to a shaft drive boat in the lower planning range say on average about 15 to 20 knots.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
