Page 4 of 11 FirstFirst 123456789 ... LastLast
Results 31 to 40 of 101
  1. #31
    Join Date
    Oct 2008
    New Forest
    Posts
    1,868
    Default Re: P'd off with Princess.
    Definition of passerelle in English:
    passerelle
    (also passarelle)
    NOUN
    1Architecture
    A footbridge.
    2Nautical
    A gangplank, a boarding ramp.
    So technically correct then, maybe someone from Princess arse covering ?.
  2. #32
    Join Date
    May 2001
    ation, Loc: ation, Loc: ation.
    Posts
    16,635
    Quote Originally Posted by henryf View Post
    On our later P50 Mk 3 the ram attaches to the vertical transom wall but lower down closer to the bathing platform compared to the video on the previous page.
    This will reduce loading due to the increased distance between the passerelle hinge and the foot of the ram. It also means you are spreading the load a bit more near a stronger right angle section as opposed to the middle of a large panel.
    Iím trying to post a picture of our stern from this phone.
    Henry
    H, does your manual give a maximum load weight for the passerelle? Seems extraordinary that it's not rated for picking up a tender.
  3. #33
    Join Date
    Mar 2002
    Posts
    17,747
    Quote Originally Posted by andy59 View Post
    A pretty dangerous arse covering, I reckon.
    If that would be their justification of the fact that an OEM passerelle whose plate states a max load of 450Kg destroyed a swim platform while lifting 160Kg, they would have a hard time convincing a court that in EN a passerelle is just a boarding ramp...
  4. #34
    Join Date
    Mar 2002
    Posts
    17,747
    Quote Originally Posted by petem View Post
    I suspect that even that wouldn't really matter, P.
    Let's assume that the manual says max load 100Kg or whatever.
    If the passerelle plate (which afaik is mandatory) states 450, and there is no other VERY visible indication of the contrary, 450 it is.
    After all, you can't pretend that anyone reads the manual before boarding: what if two guests go on the passerelle together, unknown to the captain, and they fall overboard?
  5. #35
    Join Date
    Jun 2001
    Oxfordshire
    Posts
    4,221
    Reading this with interest, but surely the max load rating of the passeralle is for its use as a gang plank. So it will support 450kg with one end resting on the dock and other end the main transom mount.
    If being used to lift a tender all the load paths will be completely different, so I can easily imagine there is no way it will lift a 160kg tender without breaking something eventually, or am I missing something?
  6. #36
    Join Date
    Apr 2013
    Posts
    318
    Quote Originally Posted by MapisM View Post
    It would be interesting to know if it did state that on the plate, I assumed he thought it was 450 but certainly seems less sure in post #21.
  7. #37
    Join Date
    May 2001
    South coast
    Posts
    3,348
    Quote Originally Posted by Chris_d View Post
    Whenever I've seen hydraulic passerelles in use, they've never been touching the dock, let alone resting on it. Perfect example of one in use here (1:05 mins in) https://youtu.be/a2eZoMt_jLo
    Ari
    If a man speaks in a forest, and there is no woman to hear him, is he still wrong..?
  8. #38
    Join Date
    Mar 2002
    Posts
    17,747
    Yup. Most hydraulic passerelle on mobos were designed to be used as cranes for lifting tenders.
    Also pretty heavy ones, like jetskis.
    The Besenzoni one fitted in my boat (which I think is the same model jrudge has on his Sq58) is rated to lift 350Kg from its tip, and it's attached to the transom accordingly.
    Nowadays, I suppose that builders are fitting lighter models, since with hi-lo platform there's no need to lift the tender.
    Anyhow, I can't remember to have ever seen an hydraulic passerelle meant to be resting on the dock at its tip anyway, also in boats with hi-lo platforms.
  9. #39
    Join Date
    Mar 2002
    Posts
    17,747
    Quote Originally Posted by NGM View Post
    Agreed.
  10. #40
    Join Date
    Jun 2011
    Volos-Athens
    Posts
    4,902
    Quote Originally Posted by ari View Post
    +1
    a hydraulic passerelle resting on the dock would rip something at the next 20cm wake!
    you take great care NOT to touch anything with the damn thing.
    btw, I'm on the other end of that:
    my AIRMAR passerelle is for 350kg or something, it's reasonably securely bolted on the plywood transom of my boat, it's happy lifting a 250kg jetrib but the ram had to be rebuilt and then made again from new material and slightly larger in dia and still leaks...
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
