Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2019
    Posts
    10
    Default Pod vs shaft engine
    Are they interchangeable? If I need to repower can I buy an ex-pod engine to install in my shaft-driven boat or an ex-shaft engine to install in my ex-pod driven boat?
  2. #2
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,440
    Default Re: Pod vs shaft engine
    You should be able to buy an ex pod ....”.bob tail “ that’s without the gear box .
    Any engine will have to be compatible with your gear box , as the ex pod ones will come without .
    Going the other way ex shaft to pod .....again it’s a mating issues don’t do it ,
    There’s a school of thought pods are Frankenstein technology.They polarise opinions .
    What are you thinking of “ breeding “ so to speak .
  3. #3
    Join Date
    Oct 2019
    Posts
    10
    I can find a used engine from a pod installation (to repower my shaft) at a good price, so I'm wondering if thete's a catch.
  4. #4
    Join Date
    Nov 2001
    scotland
    Posts
    3,446
    I don’t know if it’s the case or not but the electronics may differ however the flywheel housing should be a to standard SAE sizing but flywheels may also differ
  5. #5
    Join Date
    Apr 2007
    midlands
    Posts
    7,364
    Quote Originally Posted by scottie View Post
    The IPS engine has its sea water strainer built into the engine , the shaft version relies on the boat builder to install the sea water filtration system.
    The IPS engine may have a different map in the engine ecu to the IPS version , the rest of the managent will be totally different between each engine, you would also need a dealer to commission the engine as the PCU and HCU will require marrying to the engine, there are many versions of EVC as well so the OP would have to source the correct evolution of engine.
    This may not be an easy task .
  6. #6
    Join Date
    Oct 2019
    Posts
    10
    In other words it ain't gonna work. Thnx Paul
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
