Results 1 to 3 of 3
  1. #1
    Join Date
    May 2007
    Malta - Med Sea
    Posts
    3,679
    Default Emissions Regulations
    Strange to see only one builder (Viking) speaking about this, whose share in this size of the market is very small.
    https://www.ibinews.com/regulation/i.../35070.article
  2. #2
    Join Date
    Apr 2011
    Boat- Western Med
    Posts
    5,440
    Default Re: Emissions Regulations
    There’s an inevitability of fitting some sort of scrubbers to MY s .
    Sensibly the threshold size with this tech is reasonable .
    As the tech shrinks vol wise it will trickle down the size scale .
    As for older none scrubber boats regardless of size .
    Two thoughts .
    Scrubber only boat zones , so the if want to boat in theses waters either retro fit ( if possible) or buy a boat that meets those local requirements = waiting list , builders making hay or boaters packing in ?
    As a PR excerise to political greens at least it looks like someone is twitching a muscle in the right direction . We can’t be seen to being exempt from the diesel diesease and kill the planet theory even if leisure boats account for 0000000000000.1 % of the problem .
    “ we are in this planet thing together “
  3. #3
    Join Date
    Jan 2009
    Stratford on Avon
    Posts
    11,227
    The biggest challenge to exhaust after treatment will be the fuel quality. These will need auto quality low sulphur fuels, not readily. The engine manufacturers have all he tech to make clean diesels, but only with clean fuels, but these will be expensive and will have packaging challenges. The tech will not be retro fitted to old engines, as the fuel metering and injection systems require different combustion chamber designs, very high pressure fuel pumping and electronic sensing and metering.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
