Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. #21
    Join Date
    Oct 2002
    Plymouth
    Posts
    8,785
    Default Re: Refitting the prop - dumb question
    Quote Originally Posted by oldgit View Post
    ...and Norris deserve a boot wedged up their stern tube for selling a two quid item for that price.
  2. #22
    Join Date
    Feb 2003
    Posts
    15,771
    Quote Originally Posted by doug748 View Post
    I was looking for one a few months ago and saw that, my thoughts were along that line! I bought a Vetus one for about a fiver and thought that was too dear!
  3. #23
    Join Date
    Sep 2001
    Home - Sothampton, Boat - Gosport
    Posts
    10,676
    Nope, won't be buying it from Norris. Even think Vetus are taking the piss at a fiver, but maybe I'm forgetting the It's Marine Quality, Sir surcharge
    Steve
    Never believe anything until it has been officially denied.
  4. #24
    Join Date
    Jun 2002
    Solent
    Posts
    6,758
    You appear to have a problem if the prop came off the taper easily and is only being stopped from rotating by the key. Take the key out and lap the prop to the taper using fine valve grinding paste. Then clean it thoroughly with white spirit and try it on the shaft again. It should "wring" up tight by hand on the taper. Then replace the key making sure it is not holding the prop off the taper. If the split pin hole does not line up and its through drilled rather than castellated then the easiest solution is to get a thicker washer and reduce its thickness until tight. Conversely reduce the nut as others have suggested. A belt sander will do a good job of this if you have the skill to use it.
  5. #25
    Join Date
    Jan 2015
    Posts
    169
    I agree with boatmike. I find the best way to get the pin through the hole is file the top of the nut down, leave the mating surface alone, that way you do not need to worry too much about squareness of the filing. Try using various thicknesses of washer and get the best combination so you only need to take the minimum off the top of the nut.
    David MH
  6. #26
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    21,366
    Quote Originally Posted by davidmh View Post
    David MH
    I don't understand.
    How does filing anything off the none friction side of the nut help the nut turn a little bit further?
    Richard
  7. #27
    Join Date
    Jun 2017
    Posts
    809
    Quote Originally Posted by RichardS View Post
    I don't understand.
    Richard
    Also confused me. I can only guess he thinks the split pin is going behind a plain nut, rather than through the slot in a castellated nut.
  8. #28
    Join Date
    Nov 2009
    Posts
    21,366
    Quote Originally Posted by penberth3 View Post
    I don't think it's even a castellated nut as that could be tightened at bit more. I think it's just a nut with a hole drilled across it.
    Richard
  9. #29
    Join Date
    Feb 2008
    Suffolk
    Posts
    3,751
    Quote Originally Posted by Graham_Wright View Post
    Gosh!
    Yes - I can remember doing that as an exercise when I started my apprenticeship - what a useless exercise, filing a 4" long hexagon bar into a rectangle...
  10. #30
    Join Date
    Sep 2001
    Posts
    10,676
    I recall a friend grumbling about an exercise like that as an apprentice at Rolls Royce. I don't know if he ever used that skill, but it didn't seem to do him any harm, as he was seconded to Lockheed in the USA for a joint project and ended up working for them for the last half of his career.
    As for filing the back of the nut, I think those suggesting it are thinking of an arrangement like this
    Mine is a nut about 35mm long, drilled through each flat about 10mm from one end. I couldn't find a pic.
    The prop isn't binding on the key, it's firmly on the taper, so I don't think there's any problem there, it's just that the hole in the shaft lines up roughly with a corner of the nut when everything is tight. From the comments, I can see three possibilities, listed in order of preference: a thinner SS washer, with or without the existing one, a plastic washer that will squish up to align the holes, between the existing washer and the prop, or some delicate work with a belt sander on the nut.
    Drilling the shaft isn't a serious option as getting it out is an engine out job, and trying to drill it in place, lying on my back under the boat feels like a recipe for a drill bit broken off inside the hole and jamming everything.
    Thanks all!
    Steve
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
