Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Join Date
    Jul 2006
    Emsworth Hants
    Posts
    12,685
    Default Re: Logged cruising miles vs. Engine hours - what is average?
    Long distance sailing we barely motored we just waited for the wind to come back, we were not in a hurry. An example was on the way to the Canaries there was a two knot southerly current so we did keep moving slowly.
  2. #22
    Join Date
    Jun 2014
    Posts
    5
    Thanks to all for your responses. It sounds like Iím pretty much Mr Average - or in voter demographic speak: ĎMorbihan Maní.
  3. #23
    Join Date
    Nov 2010
    Solent
    Posts
    3,198
    Slightly off topic but does anyone know how Beta display their engine hours? I don't usually look at it much but because of this thread when I was down there today changing the oil, I did. It is saying "4545" The engine was new in 2013 and sure I motor a bit on the longer journeys, but no way have I put 190 days motoring on it.
  4. #24
    Join Date
    Feb 2006
    Me: Zummerzet Boat: Plimuff
    Posts
    3,254
    Quote Originally Posted by PhillM View Post
    Don’t know for sure but probably 454.5 hours. Yanmar have a last digit for tenths of an hour, probably fairly standard.
    Boogeying, head down, in mindless, no-nonsense sort of way
  5. #25
    Join Date
    Oct 2012
    Southminster, essex
    Posts
    9,611
    I do between 1 & 2 K miles per season & average 300 hours per annum motoring. But I do go into the Dutch canals some years.
    One year I cruised from Thames estuary to Brest & managed only 14 hours of true sailing, due to adverse or zero wind. The following year I repeated the trip & only logged about 25 hours motoring, which was almost totally taken up entering & leaving port. It is surprising how much time is taken up going in & out of harbour.
    On my 2 SH round UK trips & averaged 40% motoring but I cheated & went via the Cally canal
    I reckon 40% motoring is a typical average, even though I have a fairly quick yacht & can make good time under sail. 6kts average is often achieved. If I start to drop to 3 kts the engine goes on if I have targets to meet.
    It is all down to the fact that my wife does not understand me !!
  6. #26
    Join Date
    Aug 2010
    Bristol
    Posts
    1,119
    My dear Navigator is a sailor not a purist sailer. She dislikes getting into strange anchorages or ports in the dark and prefers to cook at anchor (Well the shore side pub or bar tempts me also). Plymouth or Scilly to S Brittany risks fatigue when shorthanded if crossing is too slow. Engine on if running late and wind contrary or lacking. Maybe 33% of miles.
    Further as a Bristol Channel sailors or as an Tamar based sailors we need to go a long way to get beyond headlands or to open water, so on our shorter trips it may be 45% of miles under engine. On "race" days we may try and sail from pontoon or mooring but normally we want to get somewhere different to our own creek. Both our boats are slow
    40% of miles under engine seems an approximate average but never bothered to log it.
    A boat is for going places
  7. #27
    Join Date
    Mar 2009
    UK, Hamble
    Posts
    603
    Using pretty accurate records we have 6.6nm per engine hour. That is engine hours as per the hour meter, so covers the time prior to cast off and after arrival before shut down. This yeas figures on their own come out at 8.65 as there were more nice days with good sailing conditions.
  8. #28
    Join Date
    Sep 2001
    Me - Zumerzet Boat - Wareham
    Posts
    12,398
    Since I bought this boat in 2000 I've done 20,330 miles and put 2,360 hrs on the engine, so that's an average of 1,070 miles and 124 hrs per year, giving a ratio of 8.61.
    MontyMariner.co.uk
    Facilitated by AWESEM WP Agency
  9. #29
    Join Date
    Jan 2008
    Solent
    Posts
    3,616
    Quote Originally Posted by LadyInBed View Post
    That's a ratio of 8.6NM : 1 engine hours. Assume an average of 5kts on passage that infers 58% of the time spent motor-sailing, but no-one knows how much of your total engine hours were for getting into and out of harbours/rivers, charging, etc - so assuming a very rough 20% of the hours for this lot, gives 46% of your time motor-sailing.
    My own figures since re-engining in 2011 are 3,070 miles and 556 hours, giving a poorer ratio of 5.5NM : 1 engine hour. I know I've spent a lot of time motoring locally and motor-sailing on passage (small stoppy boat which doesn't point high on its own), plus I hardly sailed for two years out of the nine, so the average over 7 seasons is 440 miles and 80hrs per year. If I assume a slower average of 4kts on passage for my boat, then that infers 73% motor-sailing, but knocking off an equal 20% off the hours for my own messing about, suggests I've motor-sailed for 58% of the time on passage.
    Clearly these 'results' are sensitive to the assumptions about average boat speeds and how much time spent purely motoring, etc (e.g. if I increased your average passage speed to 6kts and mine to 5kts, then our passage motor-sailing percentages will respectively increase) but they make sense in terms of your comparably higher average passage distances each year compared my own.
    I also motor-sail a lot since I'm generally slow and don't want, for example, a Channel crossing 'delivery' to take longer than 12-13hrs, so I'd use the engine to maintain 5kts minimum and help point in all but the most perfect conditions.
    Every yacht, every skipper and each cruising ground is different.
    Plan B...?
  10. #30
    Join Date
    Jan 2008
    Solent
    Posts
    3,616
    Quote Originally Posted by ithet View Post
    Looked at that way, I've averaged 5.5nm per engine hour starting in the same neck of the woods so 20% poorer... smaller boat than your's?... lousy choice of destinations... less lucky with my timings... a poorer sailor even?!
    Plan B...?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
