Re: New (to me) sailboat, new to the hobby, help me spend my savings!
I've just found this thread, have been in contact with SleepyWill quite a bit.
The rusty steel deck eyes are peculiar to your boat, part of a custom mast raising system - I've helped raise that mast and it's quite a bit heavier than standard - not a worry just be aware.
The kevlar for the keel winch is a no-no - the wire is very easy to replace as I mention in the 12 page top tips.
I will be at the club soon with the best electrician in the world looking at my boat, will contact you to maybe get a look at your boat at the same time - but I agree all you really need is a well working depthsounder and torches.
As mentioned in top tips the A22 doesn't like weight aft, I use a 65 A/H gel battery under the forepeak - a battery condition meter is very useful, I have a NASA BM-1 display and an old but useful Smiths guage from a car.
The compass cannot be really checked until afloat and able to ' swing ' calibrate it - best to use Mk1 Eyeball and charts - I'd rate good waterproof 8 X 40 binoculars with a built in compass more important than a chart plotter if budget is tight - also some sort of powerful ' searchlight ' if only from Halfords, sod's law means one does get delayed into night time especially when beginning on cruisers - but only use it if you have to as it destroys night vision - and it's never really dark at the moorings due to the bridge road lights.
Don't even think of anchoring at East Head, unless you fancy a cross between the first scenes of ' Saving Private Ryan ' and ' It's a Knockout '
I'll send recommendations,
I suggest you don't launch her too soon, it's much easier to get work done in the club - and you can plug in a 240 v fan heater !
Also most insurers don't like boats on swinging moorings over winter - and whichever one you get needs to have the topchain checked.
I don't fancy inflatable kayaks as tenders, too unstable.
I know you plan to stay in the harbour, but whenever you try the Solent do you know about the - poorly marked - submerged barrier blocks between Eastleigh / Southsea and Horse Sand fort, with a narrow marked gap at the Dolphin halfway out and a less useful one close to the Southsea beach.
The forehatch can be replaced with an ' as is ' direct replacement ' Houdini copy from Ocean Marine at Thornham Marina as mentioned - check bolt spacings and aperture size, or improved upon with say a Lewmar Ocean but that will require a little work.
Andy
Anderson 22 Owners Association - For info please ask here or PM me.
Bookmarks
