Re: Calorifier problems
I wouldn't use changeover valves on both inlet and return pipes. Also what creates the flow when using the hydronic heater - does it have its own circulation pump ?
The flow impetus from the engine is typically a take off close to the closed FW circuit water pump, with return to the header tank, but the flow isn't very strong, so it doesn't require much of a restriction to stop the flow.
Certainly your description explains the problem has occurred when the hydronic system has been introduced, so possibly poor plumbing, restrictive Tee valves, perhaps scale or sludge dislodged as a result of the work.
Also have you double checked both engine and hydronic circulation are in the same direction ?
I would dispense with the return Tee valve and consider using simple check valves in the flow from both engine and hydronic unit, using open tees in both inlet and return from the calorifier. Normal flow through the calorifier should be hot in to the upper connection and the cooler return out of the lower, this promotes natural convective flow.
When you find the cause / resolve for your problem please come back here and let us know.
Interested in Corvettes PM me for details of the Corvette Motorboat Association
Bookmarks
