Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Default Raymarine ST6002 repair
    One of the buttons on my autopilot control/display head has been accidentally hit (probably by a booted foot) and the neoprene or whatever the soft material is, has split.
    Has any forumite experience to share of mending a similar breakage or of dismantling the device and replacing the soft material successfully or otherwise, before I start? I believe that Raymarine no longer repair this model and even if they did, the service would likely be rather pricey. Perhaps someone has an old unit to offer for martyrdom?
  2. #2
    Join Date
    Feb 2006
    R Tamar
    Posts
    35
    Default Re: Raymarine ST6002 repair
    If you take the bezel off you will find the buttons come off easily and can be replaced without impacting the integrity of the unit. Second hand units appear on eBay regularly.
  3. #3
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Thanks Dave. That is useful to know. I have been looking on fleabay but generally the units offered are said to be working so significant cost would be incurred in acquisition. There must be plenty of broken units about, one of which would be ideal in view of what you have reported as to the ease of repair.
  4. #4
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Quote Originally Posted by dehlerdave View Post
    A source of replacement buttons (other than scavenged ones) would be useful. Has anyone here knowledge of such?
  5. #5
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    K
    I have removed the back plate but short of levering the pub which seems firmly fixed in place, it is not obvious to me how the bezel can be removed. The unit is a surface mounted one in case you assumed otherwise!
    Please can you explain the procedure for removing the bezel (by which I take it you mean the outer case).
  6. #6
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Quote Originally Posted by Cardinal View Post
    K
    Surely someone here has dismantled one of these before and can give me or perhaps tell me where to look for guidance before I do the unit damage please.
  7. #7
    Join Date
    Nov 2009
    Home UK Midlands / Boat Croatia
    Posts
    21,411
    The manual for my ST6001+ says:
    CAUTION:
    The control unit does not contain any user serviceable parts. It should be serviced only by authorized Raymarine service technicians.
    The control unit is a sealed unit. As a result, user maintenance is limited to the following checks:
    • make sure all cable connectors are firmly attached
    • examine the cables for signs of wear or damage – replace any damaged cables
    The installation instructions for both the raised and the flush mounted versions show that the bezel does not require removal to fit the instrument so I suspect that it might be glued and bezel removal might involve some cutting.
    Richard
  8. #8
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Richard, thanks for that. In fact I have just looked again at the unit sans back and spotted two little screws which turn out to be the retaining screws removal of which have enabled separation of guts and bezel. This has shown that the soft silicone or other button material is a single easily removable piece of that material which could easily be replaced were such parts available.
    Now I really need a discarded unit to cannibalise for an intact button cover sheet.
  9. #9
    Join Date
    Nov 2008
    From South Devon, living SE coast Spain, boat in S.Spain
    Posts
    953
    Hi,
    There are videos on youtube. The bezel can be removed by gently levering it off. I did mine without damaging it.
    M.
    Bavaria 44
    Retro navigation - the way forward
  10. #10
    Join Date
    Nov 2006
    Ardfern and Malvern
    Posts
    248
    Quote Originally Posted by emandvee44 View Post
    Hi,
    M.
    Many thanks however, as you will read above in post #8, I am now at the stage where I need a replacement button cover sheet or an old unit to cannibalise. (Or a source of new button cover sheets).
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
