Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Join Date
    Dec 2016
    Posts
    136
    Default Re: Bearing clearance question
    Quote Originally Posted by PaulRainbow View Post
    How, it's a sealed bearing ?
    "Sealed" is a relative term, not absolute, especially when it comes to the little rubber seals on 2RS bearings. I mend bicycles which sometimes use this type of industrial sealed bearing, they're not very good at keeping water out. The water ingress and rust does them in long before simple mechanical wear becomes an issue.
  2. #12
    Join Date
    May 2016
    Suffolk
    Posts
    8,200
    Quote Originally Posted by Elbows View Post
    Mechanical wear on steering pedestal bearings is likely to occur after about 1 million years. Going rusty, inside a steering pedestal would take much less time, probably only 30 or 40 years. Still, can't hurt to use stainless, some of these old boats could be around for a hundred years
    Rainbow Marine.
    www.rainbowmarine.co.uk
  3. #13
    Join Date
    Nov 2016
    Humber
    Posts
    983
    If pulling it out was the problem you can get internal bearing pullers the grip on the internal groove of the outer race, make removing very easy as the problem is often trying to pull out square.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Latest YBW News
Find Boats For Sale
to
to
